Help!
Old Mar 20, 2018 | 04:20 PM
  #41 (permalink)
Default Re: Help!
SRT6 service manual on installing the shifter assemble :
( no mention of ANY programming )
  #42 (permalink)
Default Re: Help!
Originally Posted by asusundevils23
I was just told that my car should be ready for pickup later today. Evidently, reprogramming my vehicle using the Crossfire's software is time-consuming. Is there really programming associated with replacing the shift assembly? My concern is them trying to charge me for every hour involved in said programming. Theoretically, they can claim it took 8-10 hours and I have no way of verifying it.
I would not think any programming is involved here, plug and play.
Old Mar 20, 2018 | 04:24 PM
  #43 (permalink)
Default Re: Help!
I said the same thing, but my words were like steel as I backed them up with pikturs
Old Mar 20, 2018 | 04:41 PM
  #44 (permalink)
UrbanE's Avatar
Default Re: Help!
it should be plug and play, nothing to program. Do they even have the MB Diagnostic system?
I wonder if the invoice will come with a kiss. One would hope
you should have pulled it out of there before they did the work. It sounds like the work has now been completed, to late for buyers remorse,
Old Mar 20, 2018 | 05:14 PM
  #45 (permalink)
Default Re: Help!
I saw you had mentioned it before, this is a sad thread to read.
Old Mar 20, 2018 | 06:20 PM
  #46 (permalink)
asusundevils23's Avatar
Default Re: Help!
I'm calling the mechanic now. I dropped the shift assembly off yesterday morning and it's 3pm in AZ and my car is still not ready. Something fishy is going on and I'm about to lose it. :-(
Old Mar 20, 2018 | 08:35 PM
  #47 (permalink)
Speedy4x4's Avatar
Default Re: Help!
Alot of this doesn't make sense.
Old Mar 20, 2018 | 09:43 PM
  #48 (permalink)
Default Re: Help!
Just picked it up. 597.00 bill for replacing the negative wire to my battery and replacing the shift assembly.
However, as I was driving home I could hear what resembled a fan revving both while accelerating and in idle. When I got home, I popped the hood, turned off the ignition and waiting a couple minutes. When I re-started the car I watched the engine closely. After idling normal for 10-15 seconds the engine, belts, etc. began revving fast so I quickly turned them off. I also felt abnormally hot air from the vents while driving, even though the heat was off and the outside temp was 78 degrees.
Thoughts?
Unfortunately, I may have to return to the same mechanic tomorrow off hopefully an easy fix.
Old May 3, 2018 | 09:59 PM
  #49 (permalink)
Furgal's Avatar
Default Re: Help!
Wow, Mr.Miata, thank you so very much!. There wouldn't happen to be a part# on that cord, is there? I need to order one.
I need the connector as I pulled the console out a little too hard and broke the end off of the connector under the back end of the console
Old May 3, 2018 | 10:25 PM
  #50 (permalink)
Default Re: Help!
So the newest scam in 'auto repair', apparently, is "Programming".
Seems like, not a week goes by, that I hear (either here or on Faceboook) about how someone was charged both labor and "programming" for work on a car.
Old May 3, 2018 | 11:28 PM
  #51 (permalink)
Default Re: Help!
I ended up selling my Crossfire. There was only one certified Chrysler mechanic willing to work on it and he is a 30 min drive away. The dealership 5 min down the street refused to even look at it. $2800.00 in ultimate repair costs so I elected to move on after 12 years. Hated to do it but really had no choice.
mrcrossie
Jun 24, 2018 03:29 PM
Highdollarcarguy
Jun 6, 2014 05:21 PM
FabianMoody
Feb 23, 2014 10:03 PM
lillybee
Nov 9, 2013 11:40 AM
NeverEnough
Aug 1, 2010 05:32 PM
