Crank position senser
Old Jun 12, 2019 | 07:11 PM
Rwolf's Avatar
Default Crank position senser
Okay my car is stalling and won't start it'll crank but not start. In first gear it stalls ( it is been doing this for about3 weeks). It stalled out and then I couldn't crank it. I replaced the cam shaft sensor position because I thought that was the problem. It still won't start though. I use a off brand one, and I read on here that there's only one brand that really works well. Could that new sensor be bad because it's a off brand, or is the cps not the problem?
Old Jun 12, 2019 | 08:40 PM
maggy55's Avatar
Default re: Crank position senser
The symptoms you describe are usually caused by the crankshaft position sensor. Is that the one you replaced, or was it the camshaft sensor? Bosch is the recommended brand. There are threads here about replacing the crankshaft sensor.
Old Jun 12, 2019 | 08:57 PM
Rwolf's Avatar
Default Re: Crank shaft position senser
I'm sorry it was the crank shaft sensor. Yeah, this form is awesome it helped me get it out in about 20 minutes. I just thought even offering would at least work for a little while though.
Old Jun 12, 2019 | 09:10 PM
Use only Bosch
Bosch Original Equipment 0261210170 Crankshaft Position Sensor
Amazon Amazon
Old Jun 12, 2019 | 09:17 PM
Rwolf's Avatar
Yeah, I shouldn't even tried the off market brand, but it was in stock, I've order a Bosh one from German Auto Supply, Ltd.
Old Jun 12, 2019 | 11:52 PM
Default Re: Crank position senser
For future reference use only Bosch cam and crankshaft position sensors. Other brands have been DOA.
The failed parts may not fit the socket on the harness properly, due to loose fits.
Old Jun 13, 2019 | 12:10 AM
Rwolf's Avatar
Thanks I have one on the way, and I'm sticking to them from here on out.
Old Jun 13, 2019 | 01:28 PM
So I have a spare CPS that is from Hella. Is it also highly suspect?
Old Jun 13, 2019 | 04:37 PM
If it isn't Bosch it isn't worth keeping
No other CPS has proven reliable
Old Jun 13, 2019 | 05:26 PM
Not to sling mud at any of our vendors, but Needwings still shows the Hella CPS as an option to the Bosch. Has anyone approached Needswings about discontinuing this CPS sensor. Would be interested in hearing from Needswings on this issue. Seems unlikely that Needswings would sell a CPS to us that has a history (Forum experience) of being unreliable. Just curious.
Old Jun 15, 2019 | 03:03 PM
Rwolf's Avatar
Ok the new crankshaft sensor is installed and still no start. I tried jumping it off after the new sensor was in just in case the battery was low after trying to start it with the old sensor. Any ideas I need to look into now?
Old Jun 15, 2019 | 03:54 PM
A bad crankshaft sensor will not keep it from cranking over. I don't know all the circuits that are controlled by the RCM, but that is suspect on a lot of issues.
James
Old Jun 15, 2019 | 04:28 PM
1) Sounds like it stalled and the starter would not engage (crank) - resoldering of the RCM is usually the fix. This is almost CONFIRMED if you get in, turn key to 'on' then to start, if the starter won't engage, let key go back to "on" - does engine fan speed up to warp speed in 30 seconds? If so, the RCM is at fault.
Could not crank it? What does that mean? The starter would not engage at all? Or the started engaged and spun engine over but it didn't start? I THINK It means the starter wouild not engage at all. Fix the RCM or get a new one.
If the starter won't engage and spin the engine over, the cam and crank sensors are not the issue and you have wasted a lot of time here.
If the starter IS engaging and the car won't start or won't run right, then suspect:
Crank Sensor
Lousy fuel quality
Cam sensor
Low fuel pressure
Bad MAF/IAT module
Bad Throttle body
paulius
Apr 16, 2020 04:29 PM
DualSportDad
Jul 8, 2019 04:58 PM
85daytona
Jun 11, 2019 08:55 PM
WD40
Jun 10, 2019 07:52 AM
cammons
May 29, 2019 09:01 AM
