No brake light, stuck in park, no turn over, black rectangle instead of P, P0600 Code
Old Jan 7, 2020 | 10:25 PM
ltlbull's Avatar
Angry No brake light, stuck in park, no turn over, black rectangle instead of P, P0600 Code
I am posting this new thread hoping that it will help someone else solve the same or similar issue we had with my sons 2005 Crossfire SRT-6.
2005 Crossfire SRT-6 Coupe.
Little history:
Car left us on the side of the road last summer, cut off, would turn over, but not start. After reading a lot of posts on this forum we did the RCM relay replacement of the fuel relay and re-soldered the three contacts on the RCM. This fixed the issue, at least for awhile....lol
So about a week ago we get the following symptoms:
1. Leaving the driveway the car cutoff and would not turn over. BTW...it was blocking my whole driveway...that sucked.
2. The automatic would not shift out of Park.
3. Manually engaging the release on the shifter allowed us to move the shifter to neutral. Would still not turn over but allowed us to push the car up to the garage.
4. The shift indicator was completely black (rectangle). Rest of the lights on the dash looked like a Christmass tree! All lit up!
5. No brake lights when engaging the brake.
6. OBDII scanner gave a P0600 code, Serial Communication Failure
What we did to troubleshoot:
1. Checked fuses in car and in engine compartment. No bad fuses.
2. Checked brake relay in engine compartment. Seemed OK but ordered replacement: Standard Motor Products RY-1091 Wiper Motor Control Relay
3. Replaced brake relay in engine compartment.
4. Checked camshaft and crankshaft sensors for good connections (we had replaced both of these last time it failed to start in the summer).
5. Took lower dash apart and tested brake switch. Seemed OK but ordered replacement (concerned could be worn contact inside causing intermittent failure): URO Parts 0015456409 Brake Light Switch
6. Replaced brake switch.
After doing the above and getting no joy we decided to check the connections on the RCM and PCM (fuses also). Everything seemed OK.
Just to make sure though we took the RCM apart again. This is what we found on the relay we replaced:
Rust? Is condensation forming in the RCM?
Needless to say this did not provide us a lot of confidence in the RCM. Instead of replacing the relay and testing the others we decided just to order another RCM: Standard Motor Products RY-1562 Relay
So after all that we popped in the new RCM and guess what: she started right up, no black rectangle anymore but replaced with a P and she would shift in and out of D, N , etc.
Don't ask me to explain why because I never thought all those symptoms would lead us back to the RCM....I was really afraid it was the Skreem or worse.
So in closing, I hope this information helps someone and I wanted to say thank you to everyone that posts here trying to help others. What a great group of fellow Crossfire lovers...safe driving folks!
Old Jan 8, 2020 | 11:06 AM
Default Re: No brake light, stuck in park, no turn over, black rectangle instead of P, P0600
Thanks for sharing your experience here
many of us carry a new RCM in our car just in case we need it
I’m glad ya got her up and running again
Gary
Old Jan 8, 2020 | 06:10 PM
Little history:
Great info, thanks.
Old Jan 8, 2020 | 07:20 PM
Good info.
If at all possible you should always carry a good spare RCM, cheaper and much more time saving than a tow.
Old Jan 8, 2020 | 11:14 PM
ltlbull's Avatar
I agree!
Thank you for the suggestion.
Old Jan 9, 2020 | 03:22 PM
tighed1's Avatar
Sounds like the engine control relay was going out.
I can rebuild the broken RCM for you. Keep it as a spare.
Email tighed1@hotmail.com for details.
Old Mar 28, 2024 | 01:26 PM
SteveM's Avatar
Little history:
Dude,
You are a life saver!! XFire hasn't started in months . Wife was ready to divorce me if I didn't get it fixed.. Stuck in the garage while I tried to fix it. Did all the recommendations, no help. I had all the issues you posted. Replaced the module you suggested and it started right up.
Hope others see this posting.
Thanks!!!
Old Mar 28, 2024 | 04:50 PM
zip439's Avatar
SteveM
Read post 6 above
Old Mar 29, 2024 | 06:46 AM
Little history:
Great info, thanks.
Ditto That!
NPorzelt
Nov 1, 2020 10:44 AM
autumnmass
Sep 22, 2014 08:57 AM
mbfans14
Jun 30, 2014 06:12 AM
sarahphd
Aug 28, 2007 10:06 PM
