alarm problem
Old Jul 23, 2020 | 12:10 PM
Robingaton's Avatar
Default alarm problem
hello and good day,
i recently started to have a problem with my alarm and light going off randomly but no sound or a really low sound like the alarm is trying to sound, can someone advise on what to do about this problem thanks.
Old Jul 23, 2020 | 12:34 PM
Default Re: alarm problem
Your batteries in the alarm siren are going bad. You need to at least disconnect it and at best replace it. It is under the cowl in front of the windshield. Type alarm siren in the search feature for more info.
Old Jul 23, 2020 | 07:18 PM
I have yet to see a connection to the lights flashing and the alarm going bad. I have seen a connection with the lights flashing problem with close proximity with a military base with high tech avionics AND an area with very high EMI in a local area. The odd sounding alarm is a known issue, research 'cricket on crack' and you'll see a like issue with the alarm and its failures associated with failed batteries. Disconnecting the siren under the cowl is OK but if so make sure you 'weatherize' the plug end until you either replace the siren OR sell the car. Advise you make a not to keep with the car if you do not replace the siren (leaving that winterized connector in the cowl).
Old Jul 24, 2020 | 10:27 AM
My Grandsons alarm and flashing lights were random and at all hours until I replaced his siren so ???
Old Jul 24, 2020 | 11:31 AM
Looking back we find that with the failing siren there can be the cricket on crack sound with or without the flashing lights.
The cricket on crack sound appears to mean there is irreparable damage to the circuit board.
Anyone thinking of replacing the batteries should first inspect the circuit board inside the siren to see if it is too damaged to work again with new batteries.
Old May 28, 2021 | 10:14 AM
Doc78's Avatar
Hi all thought I’d post some recent cricket on crack siren issues here.
Maybe too far gone to repair.
Maybe too far gone for repair.
Looks ok no water or battery leak damage.
Looks ok no battery or water leak damage.
Looked at it after a good cleaning with electrical contact cleaner and a polymer brush. Looks ok I will order the replacement batteries and replace worse case out 40 bucks for the pair.
I cleaned it with electric contact cleaner and a polymer brush to inspect circuit board runs looks ok
I also ordered a new buzzer off of the needswings sight listed on here for 159 if my fix works I’ll sell my refurbished on here.
Old May 28, 2021 | 11:52 AM
Originally Posted by Doc78
Hi all thought.......
Batteries less expensive here: ( https://www.ebay.com/itm/18465058626...wAAOSwm7hgHKLh ), just select 2. Good luck!
Old May 28, 2021 | 12:45 PM
Doc78's Avatar
Thanks! A little too late for me but saves others some $.
note that the shipping time on these are from June to August of 21.
Old Jul 20, 2023 | 02:56 PM
Behoff's Avatar
Could the battery failing cause a phantom drain? I was having a problem with the battery draining after about a week and a half of non-use (it’s the "fun" car these days, so it often sits that long). The dealer traced it to the siren and after pulling it out, the drain seems to have gone. My thinking is that if the rechargeable battery is not charging, it could continuously try to charge the battery, draining the main. Does that make sense?
if so, I am going to try to get inside and see if I can replace it.
I am hoping someone can confirm my reasoning.
Old Jul 20, 2023 | 04:23 PM
The batteries inside the alarm leak as they age, short out and causes battery drain. Chances are the board is fried and it would be better to replace the siren. Use the search feature on this site.
Old Aug 8, 2023 | 04:13 PM
Behoff's Avatar
It looks like you simply hacksawed the siren open. Is that right? Or is there a way to disassemble the case?
Old Aug 8, 2023 | 04:45 PM
It is sealed and can't just be opened.
Old Aug 8, 2023 | 04:50 PM
LagDan's Avatar
It has to be cut open . . . the tool used is your choice.
Daniel
BobG
Nov 29, 2018 12:24 AM
Gregm
Jun 23, 2017 12:01 AM
bhindzioncurtain
39
Jun 3, 2017 11:22 AM
Vintage Fire
May 16, 2016 08:46 PM
Hawkske
Nov 2, 2014 10:01 PM
