Help with no start
Old Oct 20, 2022 | 09:06 PM
Ronman's Avatar
Default Re: Help with no start
Yea, DJ corrected me, someone put two 20's in mine, I dont think I did that - likely it was one of the previous owners.
I'd edit all my posts but I'm too lazy.
What difference does it make if you edit your posts? The forum search algorithm is awful and the newbies love to ask the same questions over and over.
Also, do you have a pic of the item you received? Was it aftermarket or a genuine Mercedes one in a Meyle box? If it is aftermarket, I wonder if they used quality relays or the cheap ones DJ warned us about.
Old Oct 20, 2022 | 09:20 PM
When I get time I will open it and see what relays it has. It's only to be a spare anyway.
Old Oct 22, 2022 | 10:42 AM
No704's Avatar
FYI, and I know I’m jinxing myself, since replacing the battery and re soldiering the RCM my check engine light (P410) has remained dark for a whole week!
Old Oct 22, 2022 | 11:44 AM
I've owned three roadsters, two have thrown a '410 code. BOTH were fixed by reflowing the solder at those famous pins on the RCM board, so I am pretty sure you fixed that.
Old Oct 22, 2022 | 02:25 PM
Very interesting. My new RCM works, as I reported before. But I took it apart and have found interesting things about this particular item. As shown below, it is NOT what most of us have been buying.
The internal construction is different, very different. Now, the relays are still all 30 amp devices, and appear to my eye to be same or same quality as the relays we've seen before. THe board has the resistors on it and one diode, same as always.
The main board is different, same thing electrically but different physically:
Did you see the big change? The 40 amp path on the vertical board is no longer copper strips but a path on the board, kinda cheap but that's maybe why the price was $20 lower than others. SInce it's for the useless air pump, I dont care.
But there is something else: THe connector pins no longer attach to the main board, they attach to the vertical board. This appears to be an attempt to stop the solder fraction failures. Note how the pins are BIG and that they come farther thru the board and have a LOT more solder on them. Time will tell if this was effective. I don't drive the car much anymore, so if it fails in five years, it was no success.
XF90
Oct 16, 2022 09:58 PM
Paulgordon
Jul 11, 2021 10:00 PM
gompang
15
Jul 27, 2019 02:18 PM
SoonersFan
Aug 28, 2018 11:44 PM
Davgord
28
Jun 5, 2017 09:48 AM
