Chime sounding and roof selector switch flashing
Old Dec 2, 2022 | 10:25 AM
Platterus's Avatar
Default Chime sounding and roof selector switch flashing
Am hoping for help. While moving my roadster into winter storage, chime sounded when vehicle started, and eventually only came in when vehicle stopped at light. Tried using 10mm to reset the switch beneath deck lid. Roof hasn't worked all season, and have been putting roof up manually all season, and swapped out all 7 roof cylinders 2 years ago.
Old Dec 2, 2022 | 11:39 AM
Default Re: Chime sounding and roof selector switch flashing
The system thinks you did not complete the last cycle. And, it sounds like you didn't. This can be the switch you refer to, or the bow switch or the latch switch in the frame of the windshield.
Also, if the top is not working because of water damage to the CLP/SSM, that could also confuse the system and would mean you must replace the CLP/SSM and last few feet of the wiring harness leading to the CLP/SSM as well.
Old Dec 2, 2022 | 12:35 PM
Platterus's Avatar
Thanks pizzaguy. I'll look into that .
Old Dec 2, 2022 | 01:06 PM
OOPS. ALmost forgot - doing a re-sync often helps, even with a non-operational top. That is, start the engine and put the top up and down or down then up COMPLETELY including the hex bolt action on the underside of the lid.
This way, the PTCM "sees" you run thru the cycle. Never move the top, even manually, without the car running - as this confuses the PTCM.
Dschnbgr
Jan 26, 2022 09:37 AM
loudrango
Dec 12, 2019 04:21 AM
mrbluesman
May 30, 2019 10:11 AM
revs01
Dec 31, 2017 09:22 AM
johnboy1066
Oct 4, 2012 09:46 AM
