Radiator Cap milkshake
Old Dec 5, 2022 | 09:02 AM
Iskender's Avatar
Default Radiator Cap milkshake
Dear Forum members,
Greetings to you. Recently i have found that my Radiator Cap has oily milkshake (white color) on my radiator cap:
Could you please let me know if this engine oil or transmission oil?
Thank you in advance
Regards,
Iskender
Old Dec 6, 2022 | 12:16 AM
UrbanE's Avatar
Default Re: Radiator Cap milkshake
Could be head gasket, coolant and oil mixing
check the transmission fluid. If it’s clear, it should be fine.
You can have it tested to know for sure.
doesn’t look like fun.
I’m really sorry for you.
looking forward to hearing about your repair
Old Dec 6, 2022 | 09:52 AM
Wadsworth's Avatar
SRT6 or N/A? How many miles?
Old Dec 6, 2022 | 11:59 AM
How much do you drive the car?
How often do you change oil (both in months and miles/kilometers)?
When I was young, we had a tractor that sat most of the time, it would get that buildup and the shop told my dad he was letting the engine oil absorb moisture from sitting.
Old Dec 6, 2022 | 06:50 PM
How does the coolant look? If the coolant looks fine, clean off all you can and drive it. Also if the coolant looks ok, go ahead and change it out and keep an eye on it. Too early to jump to conclusions. James
Old Dec 7, 2022 | 12:29 AM
Iskender's Avatar
Dear Forum members,
Sorry forget to mention valuable data:
1. Mileage shown as 163K km but taking into account that I am not first users I am sure that it could be 400K km:
Engine temperature also good (even in summer when it were +40DEGC outside)
2. Engine is SLK 320 M112.940:
3. I have changed transmission oil on 150K (16K before) and I think I was first do this on this car because old transmission oil odor was terrible. I am using "Petro-Canada ATF D3M" transmission oil now (covering MB 236.10 requirement):
https://lubricants.petro-canada.com/en-ca/brand/atf-d3m
4. Engine oil change I am doing every 10K km and last time it was on 156K (7K before). I am using "Liqui Moly Super Leichtlauf 10W-40" engine oil now:
https://www.liqui-moly.com/en/super-...0315.html#9505
5. Currently I filled my car with distilled water for tests (on 155K when I discover the issue). I thought problem was in coolant quality - before it was very oily unknown substance. Today I have picked small amount of "distilled water" from expansion tank and here how it is looks (also oil):
Also there is oil spots in coolant:
I think coolant is not ok even if keep car temperature stable.
6. I am driving car almost daily for 20-30 km for last 8 month (since I have purchased it)
7. Shop told me that this look like transmission oil. I check it in transmission shop and they tell me that transmission oil level is ok and there is no water containment in transmission oil (unfortunately has no pictures of this)
Thank you for support
Iskandar
Old Dec 7, 2022 | 02:26 PM
NeedsWings's Avatar
looks like either bad head gasket or bad seal inside front engine case. either way i would buy a low mileage used 320 engine for $250 from a junk yard and swap that in
Old Dec 7, 2022 | 03:08 PM
philosophico's Avatar
What does the oil cap and inside of the engine from the oil cap area look light? If its a milkshake it 100% a blown headgasket. Even if its not it still likely a blown a head gasket. Welcome to the club.
Old Dec 7, 2022 | 03:14 PM
What does the exhaust look like, steamy or smoky?
I had a 3.4 L motor in an '88 Safari van after 5 years with a leaky head gasket and milky deposits like that on the oil filler cap. The GM dealer gave me the run around wanting to prove it was burning oil, which was obvious. I drove it a few more weeks then stripped the engine from the van and took it apart, every bearing surface was shot, the milky deposit was also in the valve covers, the holes for the push rods etc, the timing chain was like a piece of spaghetti.
I had the engine rebuilt better than new. That engine was known to fail in this manner and in the US it was fixed under a extended warranty, in Canada they just ignored the problem.
Old Dec 8, 2022 | 12:07 AM
Iskender's Avatar
Dear Forum member,
1. Oil cap looks ok - no "milkshake" on it and inside:
2. Exhaust is steamy:
And video:https://www.veed.io/view/4473f825-83...8-b356a42c6b27
As I can understand I need to replace head gaskets?
Thank you
Iskender
Old Dec 8, 2022 | 07:38 AM
Sussudio's Avatar
This could be a long shot but if you’ve never changed the oil cooler gaskets and 2 of the 3 failed I could see it maybe causing this problem. I changed mine at 86K and the bottom gaskets was so brittle it just snapped in half. You never know. It’s a pretty easy change except you need to find a 46mm socket.
Old Dec 8, 2022 | 08:30 AM
Jack G's Avatar
I would do a simple test to check for the presence of water in the engine oil. Get the engine completely warmed up or go for a drive, Immediately after returning siphon about 50ml of oil from crankcase and put it in a clear glass container. Let in sit for a while and see if there is a layer of coolant/water forming on the bottom. If there is the problem most likely is with the head gasket.
I also tend to agree with Rob @ NeedsWings and look into doing an engine swap. Looking at the build on the caps and inside the valve cover I would say your problem is not new and the previous owners didn't follow very good maintenance practices.
Old Dec 8, 2022 | 10:17 AM
UrbanE's Avatar
This would be, hands down, the easiest and least expensive solution. The swap is a day of your time, tops.
To replace the gasket will be both a money and activity trap.
Buy a used engine.
Old Dec 8, 2022 | 10:21 AM
Viper-666's Avatar
The engine oil will be cooled also with the coolant water. This is the adapter with the black hoses at the oil filter. In some case they corrode and oil and water will be mixed. Maybe you have a look at this adapter.
Old Dec 8, 2022 | 10:26 AM
NeedsWings's Avatar
their motor does not have an oil cooler
Old Dec 8, 2022 | 10:51 AM
Sussudio's Avatar
Ahh I didn’t see his engine pic and I saw a couple of the SRT6 guys over here and well that’s what I get for assuming. Thanks for the heads up Rob
Old Dec 10, 2022 | 08:59 AM
nemiro's Avatar
Have you checked the transmission fluid? The transmission cooler is inside the radiator. If it is leaking, it would do this, and leaking transmission coolers are a common problem in ALL makes/models of radiators. I'd check that well before I started pulling engines out.
Old Dec 17, 2022 | 10:02 AM
bc75's Avatar
You can buy combustion leak detector fluid kit at harbor freight. It would let you know if exhaust gases was getting in your coolant.
srbaker
Sep 5, 2022 11:03 AM
russthemuss
Apr 8, 2021 05:27 PM
zip439
Dec 6, 2019 03:53 PM
maxime75us
Feb 15, 2015 10:55 AM
Teck-9
Nov 12, 2009 10:23 AM
