Flickering Dome Light
Old May 12, 2023 | 09:09 PM
MDKEEHN13's Avatar
Default Flickering Dome Light
2005 limited base.
besides my cut wires post, I have removed my dead siren. No more battery drain, however I just noticed for the first time when I depress either window switch my dome light flickers. This may have been going on before. Just haven’t noticed because I have always had my done light automatic switch turned off. Just put in new led dome light bulbs and removed TPMS WIRE from slot 2 and moved to 6 . Done without ruining any other wires or sockets. So now, another dilemma to address. UGGGH
IDEAS PLEASE, if there are any. Thanks a million. And please keep in mind, I am very mechanically inclined, but far from perfect or knowing everything about our crossfires.
THANKS
Last edited by pizzaguy; May 13, 2023 at 09:12 AM. Reason: Threat title edited, as vague titles make searching even harder
Old May 13, 2023 | 06:20 AM
bluecoupe's Avatar
Default re: Flickering Dome Light
Originally Posted by MDKEEHN13
2005 limited base.
THANKS
The LED's are making the dome lights flicker when depressing the window switches. I had the same issue and went back to incandescent bulbs.
Old May 13, 2023 | 08:53 AM
My LED dome lamps flicker as they reduce/turn off. They have ALWAYS done this so I just ignore them. Small price to pay for the brighter LED light. Your issue sounds like a loose bulb, maybe? Good luck!
Old May 13, 2023 | 09:10 AM
Default Re: This is wierd
1) I just noticed for the first time when I depress either window switch my dome light flickers. This may have been going on before. 2) So now, another dilemma to address. UGGGH
THANKS
1) That is because the feed from the 200 amp fuse to splice block 100 is nothing more than two parallel runs of #10*. Block 100 powers almost every battery feed in the car (other than ABS, Cooling Fan and Pulse module). The power top motor/pump and power window battery feeds should come from a separate fuse in the little fuse box next to the battery, but they opted to put those high-current devices in with everything else. Had they done the same thing with the ABS controller, you'd see even more flickering. (*Actually, the 2007 service manual says two #10s, but my SE has only one #10 so I am not sure if ANY car actually got the two conductors.)
2) No, you are just over-critiquing the car and that is leading to you noticing normal characteristics of the car and thinking they may be problems.
Old May 13, 2023 | 10:53 AM
dcskmail's Avatar
Default Re: Flickering Dome Light
I added 2 led panel lights wired of of the bulb sockets and some hot glue to keep them in plasce & replaced the bulbs with high output led's ,
lots of light !
Old May 13, 2023 | 03:41 PM
2005 limited base.
THANKS
I have LEDs in the dome light and have not noticed any flicker, but there again I have not looked.😉
Old May 13, 2023 | 03:46 PM
MDKEEHN13's Avatar
I appreciate everyone’s comments. I was just worried I messed something up.
thanks. Can I get help with the cut wires post please ?
TheThomaswastaken
Oct 20, 2023 11:05 AM
Apr 19, 2016 12:02 PM
bmaynard06
Dec 7, 2010 03:03 AM
amcordo
Jul 13, 2008 07:05 PM
polywave
Jan 18, 2008 06:28 AM
