Radio causes parasitic battery draw
Old Mar 3, 2025 | 10:59 AM
David Whitney's Avatar
Default Radio causes parasitic battery draw
The mechanic removed my radio fuse to stop it from draining the battery. Note the radio works fine.
The stereo shop told me it is a sign the radio is kaput and can not be fixed. I am skeptical.
I am preparing to sell my car and all i want is for the radio to work and not drain the battery. Any suggestions?
Thanks.
Old Mar 3, 2025 | 11:16 AM
RJNeal's Avatar
Default Re: Radio causes parasitic battery draw
Pretty Cool sight punch your car and wala just get a replacement for it i think i saw one for `128 bucks on there.
I just Inherited a 2005 crossfire Convertible from my father and the Alternator Literally went up in Smoke at a red light 366 Bucks at Napa ouch But Dad had a Kenwood
in the garage brand new in the box , Wondered why he had that it, I had the same Problem draining the battery i guess ill be installing that after the Alternator shows up and installed .
Anyway hers the link
Chrysler Crossfire Audio – Radio, Speaker, Subwoofer, Stereo
Old Mar 4, 2025 | 01:09 AM
Thanks.
Do you know what number fuse it is? If it's number 9, that is most likely the alarm siren. You can just remove that. I have a post about that if you need help.
If it is the radio, then RJNeal is correct, your best solution is to replace it with the Kenwood. I asked about refurbishing my original, there's a Becker repair place 10 miles from me. They told me around $300 to refurbish $350 - $400.00 if I wanted to add blue tooth.
You can ask Crutchfield to make you an adapter so that there is no splicing (plug & play). Mine was $24.00 extra, but well worth it.
Here's what mine looks like. (The pictures are from a post I did when I installed mine).
Old Mar 4, 2025 | 03:13 AM
Esinclair's Avatar
These factory radios are available, I've got three. Each of mine has a problem, the one that works 100% is worn looking. But, I have one that looks great, but has a backlight issue. The other, the buttons across the top don't work.
None of mine drain the battery, and are not currently for sale.
varikyno
May 15, 2023 11:26 AM
crossfire86
Nov 30, 2011 07:45 PM
billvp
Feb 18, 2010 04:40 PM
boom182
Mar 15, 2009 04:14 PM
Chris Newman
Nov 3, 2007 01:32 PM
