BAS/ESP light and low pedal issue
Old Apr 3, 2026 | 12:54 PM
NinoBambino's Avatar
Default BAS/ESP light and low pedal issue
Hello everyone, I am new to this forum. I bought a 2008 coupe about three years ago and love the car. Have had no issues so far, but recently after sitting for a few weeks over the bad winter we had here in New England the BAS and ESP lights come on after driving a few and the brake pedal also seems low.
I checked some threads here and someone mentioned bleeding the brakes and refilling the fluid. I am trying to find that post if anyone can help.
Old Apr 3, 2026 | 03:15 PM
copperfieldkid's Avatar
Default Re: BAS/ESP light and low pedal issue
I suggest you start here: https://www.crossfireforum.org/forum...es-suspension/
Old Apr 3, 2026 | 08:06 PM
BPCR45-70's Avatar
On page 147 of your owners manual (hopefully you have one) it says that if the power supply was interrupted (battery) you should re-sync the ESP.
1. Turn the ignition switch on/run.
2. Rotate the steering wheel to center.
3. Rotate the steering wheel completely to the left.
4. Rotate the steering wheel completely to the right.
5. Bring the steering wheel back to center.
The BAS/ESP malfunction light will go out.
If it is still illuminated, we got a problem.
But for now, Cheers and enjoy this wonderful little hands on hot rod sports car.
Old Apr 3, 2026 | 08:12 PM
You might want to replace all 4 brake hoses. They deteriorate over time and become soft. The pressure in the brake lines will cause the old hoses to expand, thus producing a soft pedal.
Here are the posts that I did on replacing the hoses and bleeding the lines:
Rear Brake hose replacement
Front brake hose replacement
You can get some great videos on bleeding the brakes on you tube.
Old Apr 6, 2026 | 07:48 AM
Ptlmnulty's Avatar
I had the same issue. I bled and flushed the lines and it fixed my problem. The car had been sitting all winter.
Old Apr 6, 2026 | 09:41 AM
Thread moved to appropriate section in the forum.
Predator
Sep 20, 2024 10:14 PM
jctm17
Aug 19, 2024 01:02 AM
RReyes
Aug 6, 2023 05:35 PM
millerzrule22
Apr 11, 2015 10:15 PM
AndyJ
Oct 19, 2014 07:01 PM
