Knee Bolster Removal
Old Mar 3, 2019 | 01:48 PM
  #121 (permalink)
mariontr's Avatar
Default Re: Knee Bolster Removal
Does anyone know if this part from MB would replace the lower instrument panel on the Crossfire, the plastic is falling apart close to the ignition lock:
Lower Cover - Mercedes-Benz (170-680-15-87-7211)
Old Mar 3, 2019 | 03:34 PM
  #122 (permalink)
Originally Posted by mariontr
Does anyone know if this part from MB would replace the lower instrument panel on the Crossfire, the plastic is falling apart close to the ignition lock:Lower Cover - Mercedes-Benz (170-680-15-87-7211)
The correct part number will be moulded into your part, check and see.
I checked the part number you give, the 7211 is not part of the Mercedes number, checking without that number you get a similar looking part.
Old Apr 6, 2019 | 02:50 PM
  #123 (permalink)
gualtira's Avatar
Default Re: I Removed My Knee Bolster
How do you remove the air vent nozzle? Does it pull off?
Old Apr 9, 2019 | 08:08 AM
  #124 (permalink)
gualtira's Avatar
How do you remove the air vent part around the light switch?
Old Jul 21, 2019 | 01:51 PM
  #125 (permalink)
phil alvirez's Avatar
Default ----
eventually managed to remove the bolster. as easy as you can imagine.
thanks to you guys who provided the solution the easiest way!
now to work on attaching padding to the areas where still i can rub my legs by chance.
will tell how it went.
Old Jul 21, 2019 | 05:28 PM
  #126 (permalink)
Default what a wonderful feeling!
already am enjoying getting in without more wounds.
i dont have words to thank you who provided the short cut.
Old Jul 25, 2019 | 07:16 PM
  #127 (permalink)
as still there are some hard areas where we can hurt, i decided to do something. traced templates of those areas and cut them from a rubber mat and glued them with lepages contact cement.
the mat i found at walmart is this: https://www.walmart.ca/en/ip/hometre.../6000196605405. i know it is really memory foam because the knives loose sharpness in a moment, but the results are rewarding. the largest runs all along the area where the bolster was located; another is a half moon at the left edge of the console, where my right knee rests; another at the area behind the **** that adjusts the mirrors, and another covering the lid of the storage compartment. these 2 cushion my elbow when i rest it.
now i can move freely without the worry of geting more pain!
Old Aug 21, 2020 | 10:44 AM
  #128 (permalink)
sskalskii's Avatar
Thanks Howard. Much help in dropping the bottom panel on the way to removal of SCREEM unit
Steve
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
55chevy
Sep 13, 2015 07:38 PM
