Strange seatbelt warning
Re: Disable Seatbelt Alarm - No cutting any wires
Originally Posted by Thomas B. Whyle
The procedure for the Crossfire is as follows:
1)Turn key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2)Start engine and wait for the seat belt light to turn off.
3)Within 60 seconds unbuckle/rebuckle the seat belt 3 times - ending with buckled.
4)Turn the engine OFF and wait to hear a single chime.
(This confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function.)
Thanks to Thomas and the person who told me about this simple fix and did it for me this weekend !!!
Re: Strange seatbelt warning
I apologize for my previous post: One should never attempt a technical post when about to go to sleep. The sequence described earlier was what I used for my 300C. The correct procedure for the Crossfire is as follows: 1)Turn key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt. 2)Start engine and wait for the seat belt light to turn off. 3)Within 60 seconds unbuckle/rebuckle the seat belt 3 times - ending with buckled. 4)Turn the engine OFF and wait to hear a single chime. (This confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function.)
On #3, I usually hear a single chime just before I buckle it for the third time.
I have tried this 6+ times and it has not worked yet. What am I doing wrong?
on
I disabled that dang chime with the help/instructions found here in the forum! I did it because when I pull up to the rear gates in my yard and unbuckle, the dang thing chimes away. Annoying as hell. Sometimes it doesn't chime but then goes crazy when I put it in gear and drive 35 feet to pull into garage. I am really glad someone found this cure for that annoying chime. I wear my seatbelt whenever I take any of my cars out, just glad now when I move the car in my yard it doesn't drive me crazy. My car also chimed once when the sequence was finished, the ending chime sequence was different but the result was the same. NO MORE CHIME when I move the car a few feet, thats great!
Originally Posted by joejones
Well, I must have done it 30 times. Same results - nothing.
on
steps
09-19-2015 10:43 PM
