Cyclic Drill Noise At Idle... ???
Old Apr 13, 2011 | 04:57 AM
ant.lan's Avatar
Default Cyclic Drill Noise At Idle... ???
hi everybody,
my car as p0410 sencondary air problem, i'm tryng to buying RELAY CONTROL MODULE and the BLUE CHECK VALVE...but now i'm waiting
my car when is a little warmed and stay at idle after few seconds i hear a ciclyc like drill noise coming near the secondary AIR pump...
any ideas of the matter?
Old Apr 13, 2011 | 05:34 AM
green-ghost's Avatar
Default Re: Cycli Drill Noise At Idle... ?????
they do that, sounds like a small pump or drill for a minute or so and goes away. Dont know the tec jarjon but its ok
Old Apr 13, 2011 | 06:22 AM
Default Re: Cyclic Drill Noise At Idle... ???
Originally Posted by ant.lan
hi everybody,
Read through this post as it may have the answer to your problem.
https://www.crossfireforum.org/forum...-solution.html
Old Apr 13, 2011 | 06:33 AM
maxcichon's Avatar
Yep. Normal.
Old Apr 13, 2011 | 07:16 AM
The noise is normal but as he has that code as well it has a problem. I'm not quite sure I quite understand the description.
Old Apr 15, 2011 | 04:11 AM
ant.lan's Avatar
the car when is at idle also shake a little bit this is related with the p0410 secondary air problem?
i replaced:
-camshaft sensor
-crankshaft sensor
-spark plugs (bosch fr88dpp33+)
-air filters
-fuel filter
and cleaned MAF sensor and THROTTLE BODY
but the car is still shaking and rambling a little bit,
ANY IDEAS??????
Old Apr 15, 2011 | 08:46 AM
i replaced:
-camshaft sensor
-crankshaft sensor
-air filters
-fuel filter
ANY IDEAS??????
Vacuum hose leak?
You had the MAF off, did you install both vacuum hoses correctly?
Look at hoses to air pump.
Old Apr 15, 2011 | 09:08 AM
ant.lan's Avatar
Vacuum hose leak?
the maf seems to work correctly
i will check vacuum hoses but i don't think is this the problem...
Old Apr 15, 2011 | 09:18 AM
i replaced:
-camshaft sensor
-crankshaft sensor
-air filters
-fuel filter
ANY IDEAS??????
rumbling a little bit?
My idea is to find someone is your area and sit in their XF. These mercedes 3.2 are notorious for being a little rough at idle, not sure on the code, but there is a good chance the car is running normal.
Old Apr 15, 2011 | 12:39 PM
dtinker's Avatar
I don't know for sure, but " Secondary Air" code sounds like a vaccuum leak. Check the hoses at the top of the TB. did you have the TB off, maybe the TB gasket is not sealing off. Vac leaks would make it idle rough. Hope this helps.
Old Apr 15, 2011 | 12:42 PM
dtinker's Avatar
May be the air pump that makes the noise.
ty_ty37
Jun 27, 2024 10:42 AM
Nov 11, 2015 05:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
leaddog2015
Sep 26, 2015 08:23 PM
