Trunk cannot open!!!
Old Jul 23, 2019 | 08:48 PM
sdultra's Avatar
Default Re: Trunk cannot open!!!
OK, Here it is. A video covering how to override the pneumatic trunk lock for Coupes and Roadsters, and how to override the electronic lock for Roadsters only. I even added in a piece on the Emergency Release cable with proof that you cannot override the electronic lock with the Emergency handle.
Old Jul 24, 2019 | 12:02 PM
joozyxfire's Avatar
great video! liked and subscribed. very much appreciated for help from fellow crossfire owners.
Old Apr 3, 2022 | 08:27 PM
meh03's Avatar
I’m trying to do this on my coupe to get the hatch open. I used an endoscope so I can see what is happening, great suggestion. The pawl is engaged to the latch and it rotates when I pull on the latch but nothing. The latch freely moves the assembly rotates including on the right side but it doesn’t unlock. What am I missing?
Old Apr 3, 2022 | 09:04 PM
meh03's Avatar
I figured it out. It was all engaged and rotating properly. I took out the passenger side light and looked inside. There was a little tab up by where it rotates. I just pushed that tab up with a screwdriver. It clicked and then the latch opened.
Old Apr 3, 2022 | 09:59 PM
sdultra's Avatar
I hope you watched the video... And glad you were able to get it open.
Old Apr 4, 2022 | 01:30 PM
Good you got it open, now make sure you FIX that electrical system by completely checking it out for 'melted' wiring near/around the lamp module (as you described previously in another post). If you find none, check further. Good luck!
midasknight
Apr 20, 2014 11:30 PM
Xfire62
Sep 28, 2013 02:00 PM
itsky
Nov 27, 2011 10:07 AM
Pacemaker
Jun 19, 2011 07:29 AM
bobo54545
Nov 19, 2007 05:48 PM
