Warning lights/intermittent start
on
zip439 (04-27-2021)
Re: Warning lights/intermittent start
Check you neg cable (earth) for corrosion where is connects to the body.
on
Try to keep in mind that we are not standing next to your car, all we have to go on is what you type.
on
One way to eliminate the block-to-chassis jumper from being a problem, is to go around it, like James and I did:
Click here to gain wisdom...
Changed the battery and no real difference
checked the earth and made sure was a good contact.
Managed to get a replacement RCM.....that fixed it. Just to check wasn’t a fluke, popped old one back in....dead.....so looks like RCM was the culprit.
Thanks for all the support and advice as always.
