Rear wheel bearing and special tools?
Old Oct 19, 2009 | 04:27 PM
Default Rear wheel bearing and special tools?
I thought maybe I had a bad tire but switched them side to side and I still have the same noise in the left rear. Directional tires running backwards are really really quiet!
Anyway I suspect I have a noisey left rear wheel bearing when weight is shifted to it. Nothing dangerous yet, no play or roughness when turning by hand. The bearing can be bought for around $60 Timken. The manual lists two special tools, 9181, 9199 needed to do the job. Anyone own these tools and are they really needed? Anyone done this job before? Do I really need these tools or will a press do the same thing?
Any tips would be greatly appreciated. James
Old Oct 19, 2009 | 08:33 PM
texas t's Avatar
Talking Re: Rear wheel bearing and special tools?
James, i google this info, so here it is for what its worth.Rear wheel bearing p/n wkh757skfkit. It comes w the large snap ring and special lock nut. You have to suspend your axle assembly and hit it w/a large hammer to pop bearing apart.Because there isn"t any way to get to snap ring to remove it. First time i used a press, the second time i used a hammer. Then heat housing and freeze bearing to insert, be careful it does not take much heat 2004 coupe . Good LUck Danny
Old Oct 20, 2009 | 03:19 AM
cruzinquick's Avatar
Default Re: Rear wheel bearing and special tools?
Check out this thread. There is a write up but don't remember which site.
Crossfire Forums, Galleries - CrossfireCommunity.net
Old Oct 20, 2009 | 04:22 PM
Ok guys, thanks for the replies. Once the cold weather arrives, I will take a stab at it in the garage. For now I am still trying to deduct the issue as tires. Currently I am running my directional tires backwards to see if there is a difference. Yes only in dry weather.
James
Old Oct 20, 2009 | 04:47 PM
32krazy!'s Avatar
check out this forum. theres a section were you can rent tools from other members. its a great way to get the right tool without spending a fortune!
PeachParts Mercedes ShopForum - Powered by vBulletin
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
amx1397
Jan 24, 2016 02:12 PM
2004_
Jul 11, 2015 03:14 PM
Buchacho
Jul 9, 2015 04:13 PM
