Rs Penta Wheels
Hi All,
Just Need Some Feedback On Aftermarket Wheels ...i Have Rs Penta Wheels 19x 8.5 Offset 32 Up Front And 20x 9.5 Offset 38 On The Rears I Did A Test Fit Before Fitting The Tires I Think The Rears Will Need Some Hub Centric Spacers To Push Them Out Towards The Wheel Arch As I Dont Think That Will Be A Problem..but The Fronts Seem To Be Very Close To The Wheel Arch Lip I Know It Will Toe In Some What Once The Tires Are Fitted But It Will Be Close So I Am Taking Them Back To The Store For Them To Fit The Tires As They Recommended These Wheels For The Crossfire So If There Is A Problem They Will Have To Sort It Out...so My Question Is Have Any Of You Guys Done A Similar Setup..
Thanks..dave.
Thanks..dave.
I think you'll be fine on the front. I have 18x9 with a 30 offset with no problems. In the rear I have 18x10 with a 25 offset. I think you'll need at least a 12 mm spacer for the rear.
Les
Les
I'm just trying to help owners that have questions about stance and what will fit. (and torture certain people) You'll notice I don't have the center caps on. To get them off the wheels have to be removed so the last time at the track I left them on and ........ I lost the 2 front ones.
If I had it to do over again I would get 10 1/2 or 11's for the rear. I plan to get 285's when what I have wears out. Most likely the end of august.
(tires last me only a few months) I love this car and hope it lasts forever.
Les
Les
Originally Posted by UK DAVE
Hi All,
Thanks..dave.
Thanks..dave.
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
