Brake sensor wire replacement required?
Old Aug 15, 2011 | 09:53 PM
crookedview's Avatar
Default Brake sensor wire replacement required?
I'm going to swap out my brake pads, hopefully within the next week or so.
After searching, I didn't find a definite answer: Am I required to replace the brake wear sensor wires, or can I leave the stock ones in place if the indicator light has not yet come on?
Thanks!
Old Aug 15, 2011 | 10:27 PM
Default Re: Brake sensor wire replacement required?
I don't see any reason to replace the sensor/wire unless it is broke. The sensor and wire can be removed from your old pads and installed on your new pads. Very easy once you see it.
James
Old Sep 6, 2011 | 07:27 AM
smfrycruzr's Avatar
I can agree with James. Just put new Duralast Ceramics on the fronts, reused the sensor wire with no problems, yet....
Roty135
17
Oct 11, 2018 10:11 AM
Rooster98
Dec 24, 2015 10:59 AM
BrenLW
Aug 5, 2015 04:53 AM
Rooster98
Jul 21, 2015 12:39 PM
Mark McKay
Jul 17, 2015 01:18 PM
