Change brakes
Old Jul 8, 2014 | 06:22 PM
massanu's Avatar
Default Change brakes
Hi,
I am going to change the brakes on my SRT-6 (35K miles)
1 - Do you think I should change the rotors too or its too early ?
2 - There is a lot of brakes available in the market, I can't pick one for the SRT6. Which one have you used on yours ?
I probably gonna buy a red caliper cover too
Thanks guys, I appreciate
Old Jul 8, 2014 | 07:08 PM
Realiztik1's Avatar
Default Re: Change brakes
I have a 04 na and I had mine done at meineke. Sport ceramics all around during the 50% off promo. Cost me about 300 give or take.....2 years and im still going very strong....daily driver stop and go all that
Old Jul 9, 2014 | 05:48 AM
RED DOG's Avatar
I have been a loyal customer of BrakePerformance.com using their premium dimpled and slotted rotors on my fleet of Chrysler SRT8s and on the Crossfire SRT6s. Top quality and a truly no hassle lifetime guarantee . . . (note: pay the small extra charge for their premium brake pads . . . they are virtually dust free) . . . Below is for the Crossfire SRT6 . . . Everything is currently on sale . . .
Premium Dimpled and Slotted Brake Rotors
Front Two Rotor Set (Black) #RB-35054
You Save $10.00
$212.84
Free Shipping
Rear Two Rotor Set (Black) #RB-35048
You Save $10.00
$175.93
Free Shipping
Start here:
http://brakeperformance.com/index.php
Old Jul 9, 2014 | 06:50 AM
RED DOG's Avatar
I bought my caliper covers here:
MGP Caliper Covers
NOTE: They are available engraved "SRT6" and in a wide choice of color options BUT it is almost impossible to find the options on their website to place the order the way you want it. Suggest you phone them to place your order. The last set I bought for the rescue roadster were Satin Finish Black powder coated with silver SRT6 engraving.
Old Jul 9, 2014 | 02:46 PM
massanu's Avatar
RED DOG >
Thanks for your answers and links
So you think I should change the rotors too ? I have 35K Miles on the car and did not really drove it crazy.
Great link for the caliper cover !!
Old Jul 9, 2014 | 08:02 PM
RED DOG's Avatar
RED DOG >
If your stopping is smooth (no brake chatter which would indicate warped rotors) then you don't NEED to change the rotors. I didn't really need to change my rotors either but I went ahead and did it to get that high performance "look" as well as a bit of upgraded stopping power. The decision is up to you . . .
Old Jul 10, 2014 | 03:41 PM
massanu's Avatar
Ok so I think the rotors are still in good shape
I will go and change the pads only. Probably buying some Disc Italia Ceramic
Old Jul 12, 2014 | 10:33 PM
dinasrt's Avatar
JMO, but at 35k miles I'd probably have the rotors cleaned up (turned) and be like new again. It's cheap insurance for the best performance, and best life out of your new pads.
Old Jul 13, 2014 | 05:32 AM
massanu's Avatar
Ok weird. I have been to the garage to check the brakes and they find out that the brakes are still 80% new front and rear. And that replacing them is not necessary
Does it sounds right to you for a 35K ?
Old Jul 13, 2014 | 07:15 AM
I replaced the OEM pads at 42,000 purely to get rid of the dust, they were at about 30% wear.
I went with EBC RedStuff.
Old Jul 13, 2014 | 09:17 AM
robby363's Avatar
I have 84k on my original pads. I do need to change them soon but they do look like I could get about 90k out of them. The rotors are still in great shape other than a little lip on the outside edge of the rotor from the pad wear.
Old Jul 13, 2014 | 10:41 AM
How many miles have you put on the car, 84k?
You had it new and I guess it is garaged as rust eats away at the rotors if they are outside.
Old Jul 13, 2014 | 10:48 AM
robby363's Avatar
65,000 It had 19,000 when I bought it. It's only been garaged the last 2 years out of the 7 years I've owned it.
Old Jul 13, 2014 | 11:31 AM
the brakes on these cars are great. I changed out pads, fluid, and lines for my own performance requirements. I changed rotors on the roadster just for looks....drilled rotors, but the stock rotors are huge and will last a long time. I still run the stock rotors on the coupe with ceramic pads, high performance fluid, and metal lines. If you are just going to drive it, and not put it thru it paces, stock is fine.
Old Jul 13, 2014 | 05:37 PM
dinasrt's Avatar
You stated that you were going to do the brakes. We can just assume that you either found out that you needed to, or you wanted performance or pads that created less dust, etc. I agree about our having good brakes to begin with. Sounds like you can go quite a while longer before needing brakes. But a good idea to completely flush the brake fluid every 2 or 3 years. It could be that yours has never been changed; how old is your car now? It's especially important to change and keep the moisture out when you have an expensive ABS system like we do. Personally, I check brakes and do a fluid flush every spring with the good stuff.
Old Jul 14, 2014 | 01:08 PM
massanu's Avatar
Yes I was going to do a check on the brakes and was thinking that it was time to change them, but finally it was not the case.
But I will definitely change the brakes fluid, its a 2005 SRT-6
Old Mar 1, 2015 | 05:39 PM
KDW4Him's Avatar
How do you like the red stuff on the crossy? EBC seems to be in the minority here but for Jag they were the go to brand. I use green stuff and upgraded rotors on my daily drivers. Love the more stopping power with less effort on the green stuff.
Old Mar 1, 2015 | 06:56 PM
I have had the Red Stuff pads on the XF for 4 years now, not any wear to speak of.
However, mine is not a daily driver, but I have put 20K on her in 4 years, including 3 TOTD visits.
I have the Green Stuff pads on my 2002 Concorde Limited, no problems there either and a bunch more miles.
Old Mar 1, 2015 | 08:47 PM
KDW4Him's Avatar
Do the reds have to heat up before they fully grip? How dusty are they? How hot did they get at TOTD after a spirited run?
Old Mar 2, 2015 | 07:23 AM
I haven't noticed any difference between cold and hot.
They are very low dust, but there is some.
I never experienced any fade at TOTD, but I am not an aggressive driver.
cdcrone123
15
Nov 10, 2022 10:47 AM
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
Rets
Aug 23, 2015 06:31 PM
