Mandrus wheels
Old Nov 19, 2014 | 01:05 PM
csteve0355's Avatar
Default Mandrus wheels
I'm looking to purchase Wilhelm or Millenium with stock size tires F & R.
What width and offset should I use for no spacers or issues, and what lug bolt length should I use for these wheels so as to have no issues?
Old Nov 19, 2014 | 01:59 PM
DTMenace's Avatar
Default Re: Mandrus wheels
csteve0355
Click on the link below on the Wilhelm wheel thread and comments concerning fitment for the Crossfire...
Good Luck,
Dennis
DTMenace
https://www.crossfireforum.org/forum...s-wilhelm.html
Old Nov 19, 2014 | 06:13 PM
you have to work with the seller or store you are buying them from. Not all wheels manufactured will have the identical offsets of that of the XF. You can get close, but sometimes spacers are required. Lug bolts will not always be supplied, so those most of the time will be extra as well. You can custom order your size, but the price goes way up....if I remember correctly our offsets are 22/35.... you can use a chart that most wheel stores will have available as well....plug in your numbers and it will help select wheels. Take for instance, I moved my stock wheels out 5mm, so I had to buy lug bolts 5mm longer than stock.... Wheels can get really confusing...brake rotors/calipers have to play into the mix as well...
Old Nov 19, 2014 | 07:21 PM
maxcichon's Avatar
What Doc said.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
You'll have to do the fronts and rears separately, but you can save your profiles.
Front Stock: 225-40-18 35 offset
Rear Stock: 255-35-19 22 offset
MAKE SURE OF THESE SPECS-I'm working from 56 year-old memory!
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
