Question regarding alarm not sounding
Old Aug 16, 2016 | 05:11 PM
JACxf's Avatar
Default Question regarding alarm not sounding
Hi all, sorry if this has been solved somewhere, but I have spent a while searching and not found anything.
When I lock my (SE Roadster) car, the indicators (blinkers?) flash, the car locks and the red light on the tow away alarm switch starts to flash. However, if I reach inside and open the door (with window down or top open) no alarm sounds.
Any ideas where I should start to fault find? I am guessing that maybe the siren is disconnected? Where is the siren located on the Crossfire?
Thanks.
Old Aug 16, 2016 | 05:48 PM
Default Re: Question regarding alarm not sounding
The siren is located under the plastic cowl under the wipers, about mid way.
Old Aug 17, 2016 | 02:50 AM
JACxf's Avatar
Thanks ala_xfire, I will start there.
Old Aug 27, 2016 | 02:36 PM
lovecross's Avatar
Smile Re: Question regarding alarm not sounding
Also; the siren has it's own battery power supply, which depletes over time. Replaced siren & works again. Much info here on this subject.
Old Aug 27, 2016 | 02:56 PM
I believe European cars have a slightly different alarm system to the North American one, they have a intrusion alarm that senses movement inside the car when it is locked. This intrusion alarm can be switched off if you leave a dog inside the car for instance.
I am open to correction on this subject as I am not positive on the details.
I should look at my UK SRT6 Owners Manual - (multi language) I guess but I cannot be bothered right now.
I have often thought of selling this manual package, any offers?
It comes in the Chrysler wallet with the Navigation/Radio Manual (multi language), Warranty Booklet, Sound System Operating Instructions and a UK Dealer Directory
but it's no use now I bet.
It is in brand new condition. Photos on request.
I may put it on the for sale forum or eBay.
Old Aug 28, 2016 | 07:21 AM
JACxf's Avatar
Thanks for the offer and input 180, however my Crossfire is the US model.
I haven't had chance to get to the siren yet (I believe you have to remove the wipers, then the screws to remove the plastic panel?).
I check the other things I could think of, but I really need to check the siren.
When I lock the car and open the door, I can here a relay clicking, and the lights (front and rear) flash, but no sound. I am guessing that the logical option is the siren, but if you have any better ideas to check first I am all ears.
Thanks again.
Old Aug 28, 2016 | 07:28 AM
Most likely the batteries in the alarm have leaked and corroded the circuit board.
You have to saw the siren module apart to determine this.
Best bet is to just replace the siren module.
Old Aug 28, 2016 | 01:26 PM
lovecross's Avatar
Thanks again.
As memory serves me, (not as good as it used to), had similar symptom with original siren, it made some odd noise. Think I used the panic button to try to set it off(?) Lots of info here on replacement, wiper arms can be stubborn. Bought part online, dealer in Texas. Take your time, not too difficult.
Old Aug 29, 2016 | 10:35 AM
nickwe21's Avatar
Did you find out what the problem was?
I have the same issue. When I "trigger" my alarm (by reaching into a locked car like you said or holding down the panic button on my remote) the lights start flashing but no siren is heard. I believe this is either due to the batteries on my alarm or the alarm/siren module itself. Either way, I will have to look into that at some point but I remember reading a long time ago about batteries leaking onto the module being a fairly common problem. I think most people ultimately had to replace the whole module!
Let me know what you found out. I will look into it, too once I have more time!
Thanks!
Old Aug 30, 2016 | 09:46 AM
JACxf's Avatar
I still haven't had chance to look into it. I am on vacation this week, and hope to find the time, but my better half also has a "task list" that I am trying to work my way through
I think I am going to have to order the replacement siren from the US, as I can't find it here in the EU, and I am not sure that the EU model is the same.
I will update as soon as I get chance.
Old Aug 30, 2016 | 10:11 AM
How can you say you do not know if the EU siren is the same as the US one?
Have you looked at the part numbers? I am sure they are the same.
One replacement siren (CLICK for a picture of it) will beep when you lock or unlock the doors and the OEM siren does not.
These parts are made in Europe by Bosch so they should be readily available as they are used on many Mercedes cars.
I think you are confusing the issue and confusing yourself at the same time.
Why ask for help if you fly of on a tangent?
Old Aug 30, 2016 | 10:36 AM
JACxf's Avatar
I'm sorry if my actions offend your logic of fault finding 180, it is not my intention
I said I do not know if the part is the same, as it is the total truth, I do not know (by this I don't mean that it isn't, only that I don't know!).
I did check the part number, and after various pages of google results, the only parts with that specific number that I could find were in the US and listed for Chrysler and for Dodge.
I did also research the R170 alarm module, and there are 6 different ones that I can find, none of which coincide with the specific Chrysler part num.
I also checked 4 online suppliers that stock Crossfire parts in Europe, none of which have the Alarm module. Actually, I lie, I found one place that had a record of the part number, but the whole page was in Russian (yes, I could do a Googleation, but at that point I would rather just order from the US).
I am not sure what "fly off on a Tangent means", but according to google it means "suddenly start talking or thinking about a completely new subject", which I am sure that... oooh, cookies!!
Old Aug 30, 2016 | 10:47 AM
I once had a MB module from Ebay ( had the star emblem in the plastic horn ), but it too suffered from a dead battery after about a year.
There ARE MB compatible modules, problem is finding one that still has life left in it, and this would include any off the shelf modules with the proper Crossfire part number.
I ended up with a module from a junk yard that hadn't corroded the board, and replaced the batteries in it.
Old Aug 30, 2016 | 11:06 AM
You said you did not have the chance to look into it, I took that at face value and less than an hour later you say you have looked into it. I am not offended just confused.
I find it hard to believe that a Bosch siren with the correct part number is not available in Europe.
Old Aug 30, 2016 | 01:37 PM
JACxf's Avatar
Sorry, by "look into it", I meant actually dismantling the car to get to the siren.
I'm sure that there are equivalent Bosch parts, I guess it is a case of investigating more to find the relevant European part number.
Old Aug 30, 2016 | 01:47 PM
There are also differing part numbers (akin to finding out a top end MB will have the same guts BUT because it is in a top end car, the part number is different) that work. That top end siren price is commensurate with that top end car price as well (per-se). I was lucky enough to find the chirping replacement years ago, and wired it up in parallel to the OEM one. I suppose I should check again to see if both 'alarm' but one is hard enough on my ears. When I first installed the replacement and installed the original one in a different location, I SWEAR my hearing was damaged immensely. So, there are others that will work. I would snoop around a lot, find the least expensive 'newer' old one, and open it up first to see if replacing the batteries can give it a longer lease on life.
Old Aug 30, 2016 | 04:55 PM
Look for the part number that you have on the car or get the one I list above and get the beep when locking or unlocking the car.
Do not buy the part using the Chrysler number unless you want to pay nearly double for the same part.
Old Aug 30, 2016 | 06:13 PM
JACxf's Avatar
Thanks again all.
@180, I checked the part number that you used, and I can find that one here (listed as SLK part). Thank you kindly.
Next step is to find time to get to the siren.
Old Sep 20, 2016 | 02:44 AM
JACxf's Avatar
I forgot to update and say that I found time last week to finally get to the siren, and as you all said, the board is fried. I will order a replacement and hopefully get chance to mount it soon. Thanks.
Craig73
U.K.
Dec 26, 2015 10:14 PM
spoiler
Dec 22, 2015 09:23 PM
kusheen
Oct 13, 2003 04:25 PM
Rwright2
Sep 18, 2003 04:55 PM
texex91
Aug 18, 2003 11:08 AM
