General stereo questions (for a newbie)
Old Nov 9, 2012 | 10:44 AM
Jassonky's Avatar
Default General stereo questions (for a newbie)
Hello all. Long time lurker, first time poster.
I picked up a '04 with the Infinity system, without Navigation, several months back. Almost as soon as I got it, the left front speaker started acting up (cutting in and out), and eventually it came to a point where nothing I could do would make it stop crackling and sloshing. I had it checked out, and the tech I took it to told me that the speaker itself was damaged, and had finally just blown completely out. He also cautioned me that since the factory amp is designed to run 8 ohm speakers, it would be potentially damaging to hook up after-market speakers, as they would overwork (and eventually blow) the factory amp. He suggested that I replace it with a factory speaker.
I gave my local Chrysler dealership a call, and it turns out that individual speakers for '04 Crossfires with the Infinity system are something like $235 per speaker.
Bearing that in mind, I've decided to go big instead of going home, so I'm replacing every speaker and adding subs. My question for the experts here on the forum is this:
Was the tech I spoke to correct? If I replace the factory speakers with aftermarket speakers (I'm using Crutchfield's "what fits my car?" feature as a guide) am I going to have to pull out the factory amp and replace the factory headunit? I'm looking at adding a nice set of Infinity components to the doors, Infinity mids behind the seats, and a powered sub of some kind in the hatch. Is a setup like this possible without losing or destroying that amp?
I've got a bit of spare money to play around with at the moment, but I'm still on a budget. If I can get the system sounding nice without having to replace the headunit (and ad a new aftermarket amp for the speakers in the doors and behind the seat) it would save me a lot of cash.
Thanks in advance for any help!
Old Nov 9, 2012 | 11:22 AM
Mrmiata's Avatar
Default Re: General stereo questions (for a newbie)
First.. run from your audio person..
Read through these post.. states speakers are 2 ohm..
https://www.crossfireforum.org/forum...-thoughts.html
https://www.crossfireforum.org/forum...-help-plz.html
https://www.crossfireforum.org/forum...udio-pros.html
Search engine will bring up plenty more on here..
Old Nov 9, 2012 | 11:24 AM
Selbyl's Avatar
Check out this thread, I posted some products that will convert the signal from speaker line to RCA.
https://www.crossfireforum.org/forum...re-volume.html
This is the best way to change all your speakers, install a new amp and keep the stock head unit. The stock amp interacts with a lot of the car's functions from what I've read so it may be best to install a new amp in the hatch or under the seat for your 4 channels in the cabin and you can still have a mono amp for the subs in your trunk.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
