Need Help With Rear Differential Issue
Old Nov 25, 2012 | 09:50 PM
tje275's Avatar
Default Need Help With Rear Differential Issue
I have that howling noise in the rear differential and it is getting pretty bad even on acceleration now. I had my warranty company take a look at it and they said they wont cover it until I pay a repair shop to tear it down and show the parts have a failure in some way. My question is will you be able to see if there is a failure to the parts that is making the howling noise? Or would I be wasting my money having a repair shop tear it down for the warranty company to take a look at it? Thanks - Tim
Old Nov 25, 2012 | 10:53 PM
Mrmiata's Avatar
Default Re: Need Help With Rear Differential Issue
Just tell them it's cheaper to repair it now than when it blows up..
Old Nov 26, 2012 | 12:04 AM
tje275's Avatar
Hah I wish it was that easy but warranty companies try to get out of covering it anyway they can lol Im just trying to figure out will there be noticible damage or worn down parts that would explain the howling noise getting worse thanks
Old Nov 26, 2012 | 02:08 PM
waldig's Avatar
Talking Re: Need Help With Rear Differential Issue
Ask your question of the repair shop, they can pull the plug out and see the oil color in 1 minute and with experience tell you , also do a test drive to get their opinion for free. Woody
Old Nov 26, 2012 | 03:30 PM
It may have started with a failed bearing, but now the wear pattern on the diff will be permanently altered and the noise will be there to a much lesser degree but still noticeable.
New parts are required no matter the initial cause. A noise from the diff requires immediate repairs.
Old Nov 26, 2012 | 03:44 PM
Worth a shot :
go to Blackstone Labs and get a free test kit, send a sample of the diff oil and for a mere $25 they will report the metal content and many other things.
Old Nov 26, 2012 | 04:04 PM
Originally Posted by alaxfire
Worth a shot :
When your house is on fire you call for the fire truck, not a second opinion.
Old Nov 26, 2012 | 04:05 PM
Mrmiata's Avatar
Am I the only one that sees a very grey area here for the insurance company? "Pending failure" vrs. covered repair..
All parts on the car are a pending failure..
After my daughters heated seats shorted and caught fire..YES - CAUGHT FIRE.. and the extended warranty company covered the repair.. OF THE HEATER ELEMENT ONLY.. I just have little faith in anything short of black and white.
Old Nov 26, 2012 | 04:07 PM
Mrmiata's Avatar
Do you call them when your wife is cooking and there is smoke in the house?
I don't.. they'd be pissed at me by now..
Old Nov 26, 2012 | 04:11 PM
I won't saying anything risque about your daughters hot shorts, promise. Anyone else ..... maybe.
Old Nov 26, 2012 | 04:14 PM
Mrmiata's Avatar
Insurance company screwed her good.. so what's a post follow up comment hurt?
Old Nov 26, 2012 | 05:34 PM
No, Dave, you PARK the house so the fire doesn't spread, and send off for a RECOGNIZED second opinion that you might well be able to leverage with the insurance company.
Usually I agree with your assessments, but sometimes I just don't know where you are coming from ......
Old Nov 26, 2012 | 05:40 PM
When my rear end howls, it's from eating beans...but when the car rear end howls, it's time to tear into it, and get it repaired....so the answer is yes, they will be able to find what was causing the howling and the warrranty/insurance will have to pay up less your deductable...
Old Nov 26, 2012 | 11:36 PM
Park the house? Park the car that is of course what I am saying using a metaphor/analogy or something, get it?
You know something is wrong and there will be metal that much is obvious, why waste time when you know the result you will get back.
Old Nov 27, 2012 | 07:09 AM
The HOUSE reference was to your post :
You get the test done so you have hard evidence on paper when you negotiate with the insurance company. They normally do not act on a person's word alone.
( although I was quite surprised by Dell : I called them yesterday to have a new keyboard put in my wife's XPS laptop, they responded with "We'll have someone out tomorrow, and he will replace the keyboard, the main board and the cooling fan also, all under warranty"
( I had mentioned that it also got quite hot at times )
Old Nov 27, 2012 | 10:38 AM
Nonsense - your "warranty company" was a waste of money.
As usual.
Old Nov 27, 2012 | 10:49 AM
Mrmiata's Avatar
As usual.
I'm sure they'll cover the tow bill and repair once there is an actual failure to fix.
Like I say, otherwise your wanting them to fix a potential failure based on "it makes a noise".. no component has actually "failed" as of yet.
I'd bet on a wreck or sale before a repair if I was the warranty provider..LOL.
Old Nov 27, 2012 | 11:16 AM
A component has failed or it would not make a noise.
If a bearing has failed and the gears are out of alignment as a result the gears will get a bad mesh pattern on them if driven too far and a new bearing would only quieten the noise.The insurance company would probably only pay for a new bearing and not the damaged parts caused by the failure based on previous posts.
Old Nov 27, 2012 | 12:54 PM
boostmonkey's Avatar
Shameless plug:
I have a good spare differential unit for sale if you end up needing one.
https://www.crossfireforum.org/forum...within-us.html
The price is $325. I don't know how to change the title of the thread.
Old Nov 29, 2012 | 03:14 AM
tje275's Avatar
Thanks for all the replys, I think I got my question answered, I found a transmission and differential shop that will do the work, My insurance company told me when they tear it down they will send out an inspector and if the parts are damaged in some way and noticible they will pay for the tear down and whatever parts need to be replaced, So by your responses there should be something noticible that is causing the really bad howling noise either the bearings, gears, etc. Thanks for the help once again from the Crossfire Community
