Check engine lights
Old Oct 4, 2013 | 07:52 PM
cookiemonster131's Avatar
Default Check engine lights
ok guys 2008 20,xxx mile convertible autiomatic.
3 CEL
PO410
PO453
PO171
Any ideas where to start to repair these.
Old Oct 4, 2013 | 07:56 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Check engine lights
PO410 can be caused by the Secondary Air Pump failure due to bad contacts in the RCM. Check this out:
https://www.crossfireforum.org/forum...-no-start.html
Old Oct 4, 2013 | 08:02 PM
ok reading that seems like the RCM usually cause a no start problem. would this still be the problem if the car runs it may be a bad solder joint in the RCM?
Old Oct 4, 2013 | 08:08 PM
Yes. Starting here : https://www.crossfireforum.org/forum...0410-code.html
will lead you to the RCM. It is an easy fix so that is where I'd start.
Last edited by SparkieSRT6; Oct 4, 2013 at 08:12 PM. Reason: wrong link at first sorry!
Old Oct 4, 2013 | 08:12 PM
Sorry I had posted the wrong link in the previous post. Just corrected it !!!
Old Oct 4, 2013 | 10:49 PM
0453 - I had that one, it was caused by an abnormally high voltage (indicating fuel tank pressure all the time) which was caused by ME. I washed the car with the top down and let water get on the connector on the top of the gas tank. The ground pin corroded, and this forced a high on the sensor line.
I unplugged the connector and cleaned the pins with alcohol. Problem fixed.
171 sounds like a bad or just filthy MAF sensor. One lady in the past two weeks that showed up here actually cleaned it herself and got the car going - but HER car was running rough due to it. Can't say it set a code, I don't remember.
Get the RCM resoldered first and see what you get after that. Bad RCM solder can cause:
A no crank
A crank but no start
A fuel pump that doesn't run all the time, causing low/no fuel pressure
Other problems
If you trace the wiring, the RCM switches power to numerous feeds thru out the car. Get the whole thing resoldered and see what code(s) go away!
Old Oct 7, 2013 | 11:52 AM
awesome i will look into resoldering the rcm and go from there.
Old Oct 8, 2013 | 06:13 PM
ok pizzaguy i think i have a evap pressure solenoid problem. the car has a ton of pressure in the gas tank as it is. it is hard to put gas in so that solenoid must be stucked. i will work on all of this tomorrow....
Old Oct 8, 2013 | 06:31 PM
Would you like to rethink that statement, when you open the gas cap the pressure in the tank is the same as the pressure between your ears.
Old Oct 8, 2013 | 06:37 PM
ok so i am saying that i believe the solenoid is stuck closed. the care has a totally huge problem putting gas in it. it keeps kicking the gas pump off like it is full.
this makes sense to me now....
Old Oct 8, 2013 | 06:46 PM
bluecoupe's Avatar
maybe the tank has partially collapsed ?
Old Oct 8, 2013 | 06:48 PM
doubtful the car has electrical problems i bet it is the solenoid... i will dig into it tomorrow. anyone have any ideas on how to trouble shoot it?
Old Oct 8, 2013 | 07:09 PM
Maybe the rollover/overfill valve is jammed in a partial closed position?
This valve is at the bottom of the fill tube, it has been a problem before. It cannot be got at, the tank is non repairable. Maybe this valve could be pushed with a stick?
Old Oct 10, 2013 | 10:17 AM
i have tried and tried and tried to get this gas tank filling problem fixed and i am making no progress....
i ran a 1/8" steel rod 3 feet into the gas tank i met some resistance and passed it but the tank still will not take gas besides .15-.2 of a gallon at a time....
THIS IS FRUSTRATING
Old Oct 10, 2013 | 10:24 AM
It is not the usual bad solder on the 3 board connectors, it is burnt contacts on the air pump relay.
You can try taking the armature off that relay and cleaning up the contacts with emery paper, or you can replace the relay.
Old Oct 10, 2013 | 10:27 AM
i can do that, location of air pump relay?
Old Oct 10, 2013 | 10:29 AM
a picture is worth a thousand words :
Old Oct 10, 2013 | 10:43 AM
thank you ala!
Old Oct 10, 2013 | 01:20 PM
air pump relay contacts were clean but i polished them with emory and went ahead and resoldered the RCM 3 points that people repair.
I will test drive it as able but it is a pani right now with not being able to hardly get gas in it
Old Oct 10, 2013 | 03:37 PM
If they were clean then they should not have been touched as they are quite polished, I do not know what grade of emery you used but just the name emery means it was coarser then a polishing paper. If it is quite rough the contact may spark from different points and burn the faces.
Points are polished and normally at least one is domed to focus the spark.
That's my opinion anyway.
