oil or?
Old Nov 21, 2014 | 12:51 PM
gerry44's Avatar
Default oil or?
The book says to use Mobil 1 oil in my 2007 what would happen if I used regular oil and changed it every 3,000 miles.
Old Nov 21, 2014 | 01:18 PM
Default Re: oil or?
Can you even get 0w40 in regular oil?
Old Nov 21, 2014 | 01:33 PM
DTMenace's Avatar
Default Re: oil or?
gerry44
Were you aware of the maintenance costs when you bought the car? So you want to save some money by changing the oil and filter every 3000 miles, as opposed to using Mobil 1 every 7500 miles with a filter change?
How much are you really going to save? The sludge created by regular oil, should stop anyone from going further with your thought of using regular oil!
Dennis
DTMenace
Old Nov 21, 2014 | 01:35 PM
Larry Hitze's Avatar
Default Re: oil or?
Bad scary things would happen
Old Nov 21, 2014 | 03:02 PM
Speedy4x4's Avatar
Default
Got to Walmart the 5 qt mobile 1 0w40 synthetic is around $25 and a good filter $17.
The cheap crap not even in the right viscosity is around $15 a jug and $5 for cheapest filter.
So every 7600 miles in reccomended oil you will spend $67.
And 7500 miles worth of cheap crap $87.50 changed every 3000 miles.
Plus you would be using a viscosity that was not designed for our engines, or have the additives that is needed for the aluminum engines with the alusil coated cylinders.
We are all about finding better or saving money but bad oil is not how to do it and will coat ALOT more in the long run.
First thing I did when I bought my ssb was change fluids in everything so I knew what was in it and when it was changed.
Old Nov 21, 2014 | 03:04 PM
Default Re: oil or?
Your engine would NOT look like this at 56,000 miles :
Old Nov 21, 2014 | 09:59 PM
Default Re: oil or?
Speedy4x4 you forgot ,,to replace the engine at a cost of between $2500.00 tp $5000.00
Old Nov 21, 2014 | 10:52 PM
Speedy4x4's Avatar
Default
That is for a "used" engine.
Old Nov 21, 2014 | 10:55 PM
Abaton6's Avatar
Default Re: oil or?
Yeah,...what James,...DTM,...Larry,...Speedy....ALA,...& AMX said. ALA's picture made me switch to Mobil 1 for my whole fleet.
Old Nov 22, 2014 | 06:24 AM
Default Re: oil or?
One thing you should never go cheap on is OIL.....never. I used mobil 1 in everything....
Old Nov 22, 2014 | 12:06 PM
Default Re: oil or?
YOu'd spend as much as using the RIGHT stuff and changing it at 7000 miles, so what is the point?
(Well, unless you go with REALLY cheap oil. As has been said, Mobile 1 0W40 is really cheap at WalMart.)
I would ALSO caution you that, as also been said, 0W40 won't be available in conventional oil - and using anything heavier than 5W50 is warned against in these engines.
You won't save enough to make it worth it, gerry. I KNOW you have WalMart out there - run in there and get two jugs of 0W40 and stop by Advance or Autozone (NAPA will be pricy) and get a Fleece filter - they cost about $12 and you are good to go for around $40
Old Nov 22, 2014 | 12:21 PM
cg80's Avatar
Default Re: oil or?
The old adage : " better to be safe than sorry" really does apply here in it's most profound meaning...use the Mobil 0-40...I've used it for 120,000 miles with no issues whatsoever. ...Carl
Old Nov 22, 2014 | 12:23 PM
Speedy4x4's Avatar
Default
Have you guys looked at the new fram ultra synthetic filter, opened one up at walmart and looked at it and was impressed buy the new construction and better o rings.
Old Nov 22, 2014 | 12:30 PM
JSK's Avatar
JSK
Default Re: oil or?
I am in the Phoenix area and wonder if 0w40 might be a little light for the extreme heat here, and add to the mix the amount of heat the condenser creates under these conditions. I will say that the temp gauge stays right on center when running in the summer. Would any of you consider maybe 5w40?
Jeff K
Old Nov 22, 2014 | 12:55 PM
Bill F's Avatar
Default Re: oil or?
Jeff K
I'm in Texas and I use 5w40.
Old Nov 22, 2014 | 01:35 PM
Default Re: oil or?
Jeff K
I'm in Georgia and I use 5W50 but only in summer.
I have 0W40 in there now, as 5W50 is damn thick in the cold - as testified to by my oil pressure gauge.
Click here for approved oils as per Mercedes:
MB 229.3 - Multigrade engine oils (Specification 229.3) - Mercedes-Benz Specifications for Operating Fluids
Old Nov 22, 2014 | 01:37 PM
Default Re: oil or?
Fleece or paper? If it is paper, it won't be going in my engine.
And what exactly impressed you about the o-rings?
Old Nov 22, 2014 | 01:43 PM
Default Re: oil or?
$40 is a little conservative Pizza - by my math buying the oil at Walmart, $25 each for 2 jugs of oil $12 for a filter minus $10 for 2 unused quarts of oil is $52 and change plus tax. Still not a bad deal.
Old Nov 22, 2014 | 03:53 PM
JSK's Avatar
JSK
Default Re: oil or?
Quote...
"I'm in Georgia and I use 5W50 but only in summer.
I have 0W40 in there now, as 5W50 is damn thick in the cold - as testified to by my oil pressure gauge."
So, this got me to thinking....When we run the car in the summer it is usually to get somewhere cooler but that requires a hard hot climb to higher elevations. I don't think I would want to start the car the next morning in say Flagstaff with 5w50 oil. I think I have talked myself into running 5w40 year round unless someone convinces me that is a bad idea.
Jeff K
Old Nov 22, 2014 | 04:20 PM
Default Re: oil or?
No, I'm just saying that with 5W50 the oil pressure REALLY runs high with a cold engine when temps are below 40-45F.
But when HOT, really HOT, 0W40 produces only 2-5 pounds of pressure at idle. That freaks me out.
Well, I have no clue what temps in the AM are in Flaggstaff - so maybe I should not even respond!
