Spring damper on clutch pedal
Old Jan 10, 2019 | 11:47 AM
DaveLad's Avatar
Question Spring damper on clutch pedal
Hi everyone!.....Isn't the Crossfire a great car!! I have a 2007 soft top, 46k miles.
I have a problem with the damper spring mechanism (I think that's what it is?) attached to the side of the clutch pedal in that the point of mounting above the pedal has snapped off. The metal anchor point has snapped and looks to be made of a cheap alloy....maybe due to hot/cold cycles? (heater being on then freezing nights when the car is kept outside overnight?)
My questions are...is this a common occurance....has anyone else suffered this problem?
How important is this mechanism as the clutch works ok without it?
Finally, how tricky is the fix cos it looks damn tricky to me!? (high up behind the dash)
I would be grateful to anyone who can shed light on this problem
Cheers all!
Old Feb 7, 2019 | 12:21 AM
Cotyt94's Avatar
Default Re: Spring damper on clutch pedal
Interesting problem. I just noticed the spring on my 05 that you are talking about. I am very surprised to hear that your clutch still works!
If it were me I would try to weld it back together first, since the clutch still works for now. I would be trying to find a permanent solution as fast as possible though.
Im new to the forum so sorry I don't have any other input and good luck!
Old Feb 7, 2019 | 08:04 AM
DaveLad's Avatar
Thumbs up Re: Spring damper on clutch pedal
Hi!
Thanks for your input.....yeah, I was shocked ! when it dropped off into the footwell thinking that the clutch might not work properly....but as it has nothing to do with the actuation of the clutch mechanism and it seems to be there purely to create a smooth pedal action (iron out the hydraulic resistance when depressing the pedal), I'll see how it goes...
Also, the broken anchor point is so high up behind the dashboard that welding it back on would be, I imagine, a massive job and costly....
If things change I'll post an update.....cheers for now.
Old Feb 7, 2019 | 10:03 AM
Originally Posted by DaveLad
Hi!
Does the spring keep the pedal up and away from having the pressure pad resting on the clutch actuator. If so it would be like driving with your foot pushing on the clutch all the time.
I have hit 20,999 posts, am I a Senior Member yet?
Old Feb 7, 2019 | 10:06 AM
loggato's Avatar
The brake and clutch pedal assembly is easily removed. it's held on by 3 13mm nuts, and then you need to disconnect the brake light switch and the brake master cylinder linkage. it's just a small clip.
Then you can have access to the mechanism, or just replace the whole assembly
Old Feb 7, 2019 | 10:24 AM
DaveLad's Avatar
Hi onehundred80
Yeah good point....that would induce clutch slip....but can't say I've noticed any...even under hard acceleration...I'm convinced that it's there just to make the pedal travel smooth against the hydraulics of the clutch....I think.....perhaps.....eeerrrm...??
Old Feb 7, 2019 | 10:59 AM
Hi onehundred80
I am not sure, I had a manual once and I have forgotten what it feels like, just a thought.
No clutch slip though, does it rest on the thrust bearing that is the question.
almasyff8
Aug 23, 2011 04:42 PM
JimmySkullz
Aug 17, 2009 09:07 PM
Sdevante
Oct 20, 2008 06:55 AM
dec1184
Nov 21, 2007 04:16 AM
landho
Jun 6, 2004 08:13 PM
