alarm no worky
Old Jun 1, 2022 | 10:41 AM
mr.niftie's Avatar
Default alarm no worky
Hello,
So I started by pulling the original alarm, cut it in half, and the batteries had leaked everywhere.
Ordered a new one from Needswings and installed it yesterday.
Good news it that the chirp now works with lock/unlock.
Bad news is that I can't trigger the alarm from the remote's panic button.
Thoughts???
Michael
Old Jun 1, 2022 | 10:49 AM
Default Re: alarm no worky
Whatever you do. don't panic!!!
Sorry, I couldn't resist.
Old Jun 2, 2022 | 09:55 AM
NeedsWings's Avatar
have you tried with both keys? the panic buttons are the first thing to fail on the keyfobs.
Old Jun 2, 2022 | 11:10 AM
mr.niftie's Avatar
Yes I tried both remotes. 1 is the original and the other is new and programmed a month ago. Weird…
Old Jun 2, 2022 | 11:15 AM
I believe that they do not go off as soon as the button is pressed but after a few seconds. Are you waiting long enough?
Old Jun 2, 2022 | 11:17 AM
mr.niftie's Avatar
I’ve tried multiple pressings in a row and keeping my finger on the button for various lengths even over 12 seconds.
Old Jun 2, 2022 | 12:55 PM
NeedsWings's Avatar
roll down driver window
turn off car and remove key
close door
lock car with remote
wait a minute
reach in through window and open door from inside handle
does the alarm go off now?
Old Jun 2, 2022 | 05:34 PM
mr.niftie's Avatar
close door
wait a minute
That worked! So I assume that means that the car is good and the new alarm is good??
So I guess this means that both remotes have a defective alarm button?
Old Jun 2, 2022 | 06:02 PM
That may be a wrong assumption.
Old Jun 3, 2022 | 06:59 AM
mr.niftie's Avatar
Not sure if I mentioned, but I did check the fuses under hood.
I am open to a correct assumption
Old Jun 3, 2022 | 10:07 AM
Thank goodness I've never had a need for a panic button.
Old Jun 3, 2022 | 10:57 AM
mr.niftie's Avatar
Agreed, but since my wife and daughter will be driving from time to time, it would give me comfort in having it work.
Old Jun 3, 2022 | 04:20 PM
I had an occasion to 'replace' the red button on one of my FOB's with one from a NEW eBay FOB case. The red 'pin' flared and the center portion disintegrated over time. Popped off (carefully) the red 'panic' button parts off the working FOB, and popped off the panic button off a NEW replacement FOB case (again, carefully), and the fit was perfect. Maybe, just maybe, your FOB circuit board switch is fine, and that red plastic 'panic' button pin is distorted and not correctly pushing the location where it should on the circuit board. Here below is the one I purchased, if this might be your issue. To help, you might be able to remove your 'panic' button (carefully) and push (gently) a clean-cut end of a toothpick into the hole and press the button to see if the switch is actually working. Here (https://www.ebay.com/sch/m.html?_ssn...sfire&_sacat=0) is where I got my replacement (there was no place I could find, for just the red panic button part). While I was at it, I also replaced the entire ''black' insert as well since it was slightly scratched from other stuff in my pocket over the years. Hope this helps! Good luck!
Old Jun 5, 2022 | 10:15 AM
mr.niftie's Avatar
Thanks for the advice. I should have mentioned that the one fob is old (possibly the original) and the other fob is brand new. And neither one works.
Old Jun 6, 2022 | 06:28 PM
mr.niftie's Avatar
Any thoughts for next steps?
Old Jun 18, 2022 | 09:10 AM
mr.niftie's Avatar
If anyone has anymore thoughts I'd appreciate the feedback.
Michael
Old Jun 18, 2022 | 09:39 AM
Contact Josh Chase at the Mercedes Swap Shop.
Old Jun 20, 2022 | 01:09 PM
Chryscross1's Avatar
Anyone have an issue with their car alarm going off spontaneously and the alarm sounding very low?
If so, how was it repaired?
Thanks,
Old Jun 20, 2022 | 01:17 PM
Use the search at the top of the page. Just type in replace alarm siren.
Old Jun 20, 2022 | 01:18 PM
NeedsWings's Avatar
Thanks,
your alarm siren is bad
nickwe21.
Nov 3, 2024 09:56 AM
maggy55
Nov 19, 2021 02:43 PM
cdlrodgersrns
Jul 30, 2021 08:47 AM
Vintage Fire
May 16, 2016 08:46 PM
WestKyOnXFire
May 21, 2012 01:51 PM
