Check Engine and Wing up
Old Jun 5, 2022 | 11:20 AM
Scott_lmtd's Avatar
Default Check Engine and Wing up
Hello all,
unfortanatly my Crossfire has been in the garage for some time (under a cover and trickle charge) but went to take her out and had a check engine light and wing up situation. Suspect the Wing up is battery, although that surprised me since the battery isn't to old and its been on a trickle charge the entire time in the garage. I don't want to mess with battery (if thats it) until I figure out the check engine light. So looking for some input
ODB scan tool- any recomendations to one, just need something to read out the error code(s), not plans to tweak things. Saw some on Amazon that appeared resonable
If anyone is on the east side of Orlando and doesn't mind me borrowing I would appreciate that.
Wing up, if not battery is that an indicator of something else?
thanks all
Scott
Old Jun 5, 2022 | 11:30 AM
Default Re: Check Engine and Wing up
For a cheaper one, I like the BOSCH 1100. Gives live data, which is fun and helpful.
Wing up is almost always battery but if you drive it and have no speedometer or it refuses to come out of park, the RCM's traction control output is missing (bad fuse, bad relay, fractured solder connection).
Old Jun 5, 2022 | 11:35 AM
Scott_lmtd's Avatar
Thanks Pizza Guy. Was hoping to get away cheaper but its not to bad and does look like it reads ABS too.
Well, took for a quick spin and no speedometer movement. Will check fuses and relay. Thanks
Old Jun 5, 2022 | 12:12 PM
Scott_lmtd's Avatar
Further confirmation, Pulled the fuses in the RCM box and all looked fine (15Amp). Any idea where the relay is that can re-seat?
What are options if the relay is good, is the traction control unit something that can be repaired?
Also, the ABS - BAS/ESP lights are on. I've seen that before, went off after pumping the brakes a few times since it was sitting. Didn't go off this time with a short run around the block. Ugg,wonder if this is all connected.
Old Jun 5, 2022 | 01:07 PM
DJ rebuilds the RCMs for about 60 bucks.
Old Jun 5, 2022 | 01:09 PM
Scott_lmtd's Avatar
Thanks Zeracer, just found his thread and sent an email!
Old Jun 17, 2022 | 05:35 PM
Scott_lmtd's Avatar
Default Re: Check Engine and Wing up- Thank you!!!
Big thank you shout out to Zeracer for helping troubleshoot my issue and to D.J. rebulding my RCM and quick turn back. Had a chance to drive today (finally) and everything is great. The wing up was also due to the RCM
thanks again!
Old Jun 17, 2022 | 05:56 PM
Thanks for letting everyone know the outcome.
TerryR
Feb 14, 2016 11:27 AM
cynsational
Sep 16, 2014 06:27 PM
Stuckhere
Mar 12, 2010 06:20 AM
LantanaTX
Sep 9, 2009 07:35 PM
OzCrossfire
Jul 26, 2008 06:03 PM
