Parisitic Battery Drain, TPMS Module
Old Nov 19, 2023 | 11:38 AM
dbaksa's Avatar
Cool Parisitic Battery Drain, TPMS Module
I have owned a 2006 Crossfire basic Roadster since 2007. Just recently it has developed a parasitic drain on the circuit connected to fuse 9 (TPMS, Security, Horn,Interior lights). Everything seems to work correctly and amperage measures change as different options are used. I can't test TPMS because the TPS sensors in the wheels were unknowingly removed when tires were replaced. I cant seem to locate the TPS module to disconnect it and determine if it is indeed the module. The hack found on YouTube suggesting disconnection of the gray yellow wire cant be used as I don't have a garage door opener built into the headliner.
Thanks in advance,
Dan
Old Nov 19, 2023 | 11:43 AM
Ronman's Avatar
Default Re: Parisitic Battery Drain, TPMS Module
Thanks in advance,
Dan
The garage door opener is where the TPMS module is located. So you just have a hole in your headliner? The parasitic drain is most likely the alarm siren location inside the cowl, disconnect it and see if the drain disappears.
Old Nov 19, 2023 | 11:58 AM
TPMS does not affect the car battery.
Old Nov 19, 2023 | 12:10 PM
dbaksa's Avatar
Thanks for the quick response. I will take a look and update the post if that solves the problem.
Thank,
Dan
Old Nov 19, 2023 | 09:37 PM
Thanks in advance,
Dan
I do not believe the wire to disconnect the TPMS is located in the garage door opener electronics. The connector for the TPMS module wiring is further back BEHIND where the garage door opener module would be located (many if not all TPMS modules have a wad of foam wrapped around it). Or, am I reading this all wrong?
Old Nov 20, 2023 | 09:59 AM
dbaksa's Avatar
RONMAN,
hanks for the tip. I disconnected the siren under the cowl as yo suggested and the battery drain is gone.
Thanks again..
Dan
Bayukbros
Feb 20, 2023 08:49 AM
Bayukbros
Feb 25, 2022 08:57 PM
Bayukbros
Feb 17, 2022 09:26 PM
go@midnavi.com
May 18, 2020 11:07 AM
Arcrist
Aug 5, 2019 08:42 PM
