door speakers blew and clueless on replacement
Old Mar 15, 2012 | 04:37 PM
carpen04's Avatar
Default door speakers blew and clueless on replacement
i blew the big door speakers and i need to replace them. i do not want to change the head unit which is fine but i would like to find a better set of door speakers then oem , A FIT RIGHT IN AND PLAY type..are
Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance Two-Way Speakers (Pair) a better choice then oem?. they are on amazon for 45 bucks
thanks for your help
Old Mar 15, 2012 | 04:47 PM
sk8erjosh09's Avatar
Default Re: door speakers blew and clueless on replacement
If I remember correctly the amp only puts out 22W RMS, so 180W speakers (probably peak, so 90W) would require more power to remain constant. Not that its a huge deal (Im currently underpowering subs) but you may want to find something with less peak/RMS. Im picky with speakers and usually stick with Kicker, but you should check out Kenwood or MTX as well. Try to find a speaker to match the current amps output. Or buy componet speakers with amps all ready to go. Hopefully this helps.
Old Apr 7, 2012 | 09:30 AM
carpen04's Avatar
haha i have no idea what to look for. i just want speakers i can fit right in and play. i am not smart on this stuff so i need help finding a set. i went to best buy and no help. i would like better quality if i can without modifying anything.
Old Apr 7, 2012 | 09:38 AM
waldig's Avatar
Talking Re: door speakers blew and clueless on replacement
Pull them or one out and go on ebay or amazon to check the size of the mounting. Having it in your hand is real handy when checking the connections to the leads and size / spacing of the holes. If I ever get to mine Iam adding the caps to cut the danm base, too too much. Woody
Old Apr 7, 2012 | 10:31 AM
arejohn's Avatar
Look here:
Car Selector
Old Apr 7, 2012 | 10:44 AM
turbomar's Avatar
I had one go bad and this is what I put in:
6.5 Car Speakers Rear Door 3way 250w 4ohm 6503-RD | eBay
Old Apr 7, 2012 | 02:29 PM
Mrmiata's Avatar
You mean having an extra 15 minutes? That little panel on the upper corner pops out and give instant access to the wires..
Old Apr 7, 2012 | 04:26 PM
maxcichon's Avatar
These are the speakers I installed and they sound absolutely great.
Plug-n-play. Correct impedance too.
These:
http://www.amazon.com/Infinity-Refer...3834836&sr=8-2
Old Apr 7, 2012 | 04:29 PM
maxcichon's Avatar
These Infinity's are quite efficient. Their power handling capability is really not an issue.
Much louder (crude way of putting it!) for a given "volume" setting than the OEM things. And much better sounding. Try it-you'll like it!
Old Apr 7, 2012 | 04:45 PM
maxcichon's Avatar
4.5 stars at Crutchfield. And $120!
Infinity Reference 6032cf 6-3/4" 2-way car speakers — also fit 6-1/2" openings at Crutchfield.com
Old Apr 7, 2012 | 05:12 PM
Mrmiata's Avatar
And a half price sale on Ebay.
Infinity Reference 6032cf | eBay
Old Apr 7, 2012 | 06:05 PM
Nice price on here as well ( Amazon.com: Used and New: Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance Two-Way Speakers (Pair) ).
Old Apr 7, 2012 | 06:18 PM
robertalive's Avatar
dude the Alpine 6.5 r series speakers sound great and at techronics .com they have the best price.6 1/2 r series only dont buy e or s series for the money Alpine r at 70 or so dollars its the best for the money unless you want Focal.at techronics they have the 6 1/2 component system which handles 110 watts rms and if you ever upgrade the amp itll handle sounds great and gives you a crossover and you can mount the tweeters on the pillars.they charge 138 or so everyone else wants alot more its brand new factory sealed with a warranty.i bout alpines 8 years ago and they still play in my buddies car.good luck
Old Apr 7, 2012 | 06:22 PM
Exactly how hard is it to swap out these speakers? Do you need to remove the door panel? How easy is it to pop off the speaker trim ring? That would ultimately be the deciding factor to replace, if my speakers are not blown.
Old Apr 7, 2012 | 06:37 PM
syfi's Avatar
Replaced my blown OEMs with the 6030cs Infinity. Also plug and play (2 ohms). Fantastic sound.....
Amazon.com: Infinity Reference 6030cs 6.5-Inch 270-Watt Two-Way Component System: Electronics
Old Apr 7, 2012 | 07:43 PM
turbomar's Avatar
Post edited:
https://www.crossfireforum.org/forum...oor-panel.html
Old Apr 8, 2012 | 12:36 AM
maxcichon's Avatar
Originally Posted by turbomar
Yes, you have to remove the door panel. The speaker ring remains on the panel. The door handle splits in half revealing 2 screws. Pop the SRS patch to reveal another. Remove the door jam end plate and striker plastic molding
will get you there...
There is a sticky for the door panel removal. It will get you there...
Hoppy
Dec 7, 2018 07:36 AM
RED DOG
Jul 21, 2015 07:58 AM
chturner
Jul 17, 2015 12:33 PM
66L72M21
Jul 15, 2015 04:23 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
