Electric Window Blowing 40amp Fuse!
Old Nov 10, 2012 | 05:50 PM
Albert L. Murphree's Avatar
Default Electric Window Blowing 40amp Fuse!
Every time I try to roll down the right side window, it blows the 40amp fuse. I replaced the motor 1.5 years ago (By Dealer) it stopped the problem for a little while. Now it is doing it again! I am being told it is the Body Control Module? I dosconnected the window motor and ran it off a seperate circutt with 11 amp fuse and it did fine! When I connect it back the the wiring harness POW! it pops the fuse. The antitheift is not working either. Dealer wants $ 2,400.00 to replace the BCM! Any thoughts?
Old Nov 10, 2012 | 06:25 PM
Default Re: Electric Window Blowing 40amp Fuse!
I'd have a look at the switch. Automotive switches are made like crap.
Start at the cheap end of the fix and work your way toward the BCM. Then start at the motor and work back to the BCM. There's probably a short somewhere.
Old Nov 10, 2012 | 06:46 PM
waldig's Avatar
Is the window pinching the cable? Is there a rub??. The motor is the only thing that can draw that much current other than a cable pinch. You tested the motor alone.. woody
Old Nov 14, 2012 | 12:03 PM
Woody, the motor is fine. I am being tol the BCM is out. Because My alarm and the switch for the motion decetor is not working as well. Looked at the wiring an do not see any rubs or etc. I need a wiring schematic for the car. Guess I will have to find one some where.
Old Nov 14, 2012 | 12:21 PM
What motion detector? Do you mean the anti tow feature?
The wiring diagrams are on this site in the repair manuals and you can go to them via the link in my sig.below.
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
Charlesl
Sep 30, 2015 10:46 PM
