Infinity front speaker replacement help/advice
Old Mar 2, 2013 | 11:02 AM
zombiehunter's Avatar
Default Infinity front speaker replacement help/advice
Hi! I've searched and come up with a bunch of threads but so far every time I do that someone posts some really solid advice after I'm done that would have saved me 4 headaches, 3 busted knuckles, 2 hours of time and a **** load of bad words.
In this thread I found these speakers and ordered them from
Amazon Amazon
Supposed to be plug and play. I'm terrified of breaking something when I take the door panels off, instructions here.
Thoughts? Advice? Well wishes?
Old Mar 2, 2013 | 04:51 PM
maxcichon's Avatar
Default Re: Infinity front speaker replacement help/advice
It is pretty straight forward. The only thing I had to do was trim a itty-bitty bit of metal from the mounting "ears" on the speakers to fit into the basket (you'll see).
You'll want to "push" the old speakers out. They are held in place with an adhesive gasket. Steady, firm pressure (on the back of the magnet) will get it loose.
Old Mar 2, 2013 | 08:31 PM
Lastly, is there anything I should try first before replacing it to make sure it's actually blown?
Old Mar 2, 2013 | 08:41 PM
Easley15's Avatar
you can tell if they are blown just from the sound of the speaker
Old Mar 2, 2013 | 08:53 PM
Mrmiata's Avatar
Or.. if you have no sound from it.. you should still hear something out of the tweeter... same wires running to it.. and you can access the wiring right there by pulling the little panel (near outside mirror area on the interior panel) .. not impossible somebody did bang for buck stereo mod and wires have run amuck.. LOL.
Old Mar 3, 2013 | 01:28 PM
Those speakers will work with the stock amp right? or will i have to do something for the tweeters since the stock ones are separate?
Old Mar 3, 2013 | 01:32 PM
Here's what he said:
they may fit your door mid bass place no issues, but the sound signal is separated with your factory system
your not getting a full range sound out the speaker you are replacing these with
And then he suggested these:
http://www.sonicelectronix.com/item_...al-165-A1.html
Old Mar 3, 2013 | 03:02 PM
maxcichon's Avatar
I installed these:
Infinity 6032cf 6-1/2" 2-Way Reference Series Car Speakers
and kept the OEM tweeters. 200% improvment in sound and ~ 50% increase in volume. They seem to be much more efficient than the OEM setup. I'm sure (?) your tweeters are fine-why replace them?
Old Mar 3, 2013 | 03:15 PM
the speakers you linked seem to be the same, so will the tweeters on the speakers in the door work as well as the OEM tweeters? I'm sorry, I know nothing about car audio/audio.
Old Mar 3, 2013 | 07:28 PM
Mrmiata's Avatar
Yep.. install them.. then tweet that you have a quad tweeter setup..
Old Mar 4, 2013 | 08:02 AM
maxcichon's Avatar
You are completely correct. They should work better than mine! I would guess the dongle would replace the caps in the "Best Bang..." setup!
One other thing-there's a switch on the front of each speaker to lessen the tweeter volume. I would install ONE new speaker and listen to it. Then decide which way you like it.
I opted for the reduced high frequency response.
And if it swivels- make sure it's pointed UP at you.
Old Mar 4, 2013 | 08:54 PM
I do it for the lulz Thanks again for finding me that amp, you've no idea how nice it is to have a radio back after so long
Old Mar 4, 2013 | 09:18 PM
Mrmiata's Avatar
Not a problem man.. Always out to help a forum member when I can.. along with pretty much everyone else on here.
That's kinda the heartbeat of this forum.. and probably why I get a little tweaked when someone comes on here trying to rip members off.. especially newbie's who don't have a clue about things..
Just pay it forward when the time comes along..
Old Mar 27, 2013 | 07:20 PM
BrianBrave's Avatar
<--- Huge Horsepower
Bad speakers generally have one of four problems.
1. burned voice coil - smell the speaker cone near the magnet - you'll know - it's cooked so just toss...
2. ripped surround - look at the rubber surround the attaches the cone to the outer frame for rips and tears. If the tear is small enough, it can be repaired with flexible glue/cement.
3. Delaminated Spider - see if you can carefully lift the spider off the frame - if so, glue with some loctite glue and clamp. This picture shows a spider that been ripped - driver no good.
4. Broken wire from connector to voice coil - set you ohm meter to under 20 ohms and measure the resistance... if you get anyware from 1.8 - to 8.2 ohms (depending on a 2, 4 or 8 ohm driver), then wire and voice coil are fine.
Old Mar 27, 2013 | 07:26 PM
BrianBrave's Avatar
Remember - ohms law and impedance.
Speaker drivers wired in parallel will half the total circuit impedance and thus draw more current - be sure the amp can handle it when at high volumes or ....
massanu
Feb 20, 2019 07:06 PM
tom2112
Jul 28, 2015 08:12 AM
Trenzman
Jul 24, 2015 10:12 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
axnguyen
Jul 21, 2015 11:41 AM
