Forward facing subwoofers in roadster
Old Jul 2, 2024 | 12:25 PM
Default Re: Forward facing subwoofers in roadster
THe first car I saw with front-facing rear speakers was Mary Diaz's car in Atlanta - a base coupe.
The system was so much better sounding than factory. BY FAR.
Old Jul 8, 2024 | 08:03 PM
bossman4's Avatar
I am assuming that you cut a hole in the carpet that matched the inner diameter of the fabricated mount and then drilled through the carpet for the mounting screws for the woofer speaker frame.
Then you mounted the speaker cover on top of the mounted speaker.
So, if additional maintenance behind the carpet is required, the midrange woofer needs to be removed before the carpet is pulled away from the back.
Old Jul 8, 2024 | 08:37 PM
UrbanE's Avatar
100% correct
the only item not installed are covers over the speakers.
they’re behind the seat backs so I didn’t bother.
I did discover one downside.
Another full day on the highway, rear speakers were turned up and thumping along.
Couldn’t figure out why I needed to stop every 90 minutes for. Rest stop break. Then it hit me. The subs were Eviscerating my kidneys.
but the sound was great.
Old Jul 8, 2024 | 09:50 PM
bossman4's Avatar
Cool! Does not sound good for old guys like me.
FUBU
Jun 30, 2014 01:26 PM
Bonefishmak
Jul 20, 2013 01:58 PM
HyprLtH20
May 16, 2010 02:56 PM
Vicar of Sterling
Jun 10, 2009 10:16 AM
