Keys to remove radio
Old Nov 15, 2023 | 02:25 PM
Robgauss's Avatar
Default Keys to remove radio
In searching these threads I see reference to using keys to remove the radio. I see the slots for them but have no keys. I see keys available on eBay but they various designs for MB, Dodge and such.
would you know where I might find the correct key or a known workaround?
thank you.
Old Nov 15, 2023 | 03:57 PM
Default Re: Keys to remove radio
Go to Amazon and enter radio removal tool kit.
Old Nov 15, 2023 | 04:04 PM
Robgauss's Avatar
Thank you, yes, there are many versions of it on Amazon and EBay. Not sure if I need the U shaped wire version or the actual key. Was hoping someone on this forum may know,
Old Nov 15, 2023 | 04:32 PM
These are the keys, you only need two.
Walmart has them I believe.
CLICK CLICK
Old Nov 16, 2023 | 09:36 AM
UrbanE's Avatar
This is a great tool.
try searching here
you’ll be amazed at the wonders that await
Old Nov 16, 2023 | 10:09 AM
Robgauss's Avatar
Yes, Google is a great resource but you will find that the results are the same conflicting choices- U-shaped wire or key, and there are variations of that. Fortunately I was able to get a specific answer and have ordered the part.
Thank you!
Old Nov 17, 2023 | 09:21 AM
Thank you!
All the information is here , on the forum. If you would click and read the link below, in my sigline, I explain how to make Google work when searching THIS forum. Generally, I can find anything I am looking for on this forum in under two minutes using my technique. But you must "help" google know where you want it to search, I go into that in my link below.
What I cannot do, is get people to READ. You can't help people who dont want help, they want things done for them. (Not necessarily talking about you.)
Old Nov 17, 2023 | 10:51 AM
Robgauss's Avatar
Something else I would recommend when searching Google specially is to use double quotes around your search criteria phrase. It helps to really pin it down.
”Thank you!”
Roy Mander
Aug 3, 2014 05:46 PM
gcong
Aug 3, 2012 12:28 PM
Erzer
Jul 26, 2011 01:12 PM
scott0825
Oct 30, 2010 12:29 PM
DarkhelmetRT
Aug 12, 2009 03:13 PM
