dip stick vs. level sensor
Old Sep 24, 2012 | 11:21 PM
bieber's Avatar
Default dip stick vs. level sensor
My 1st oil change with 8 quarts (thanks forum, 2004 manuals say 6 qrts.), was exactly to the top of the norman range on the dipstick and the level sensor said "OK".
Now at 3500 miles since the change the level sensor says "- 1.0 qt" BUT it is only about 1/5 of the way down from the top of the normal rnage on the dip stick. I do not want to overfill it.
The question is, is the range on the dipstick really "one quart from low to full" like the manual says (and I am ony 1/5 of a qt. low) or is the manual WRONG (just like it is when it says that an oil change is 6 quarts) and I am really one whole quart low like the sensor is indicating? If the level sensor is correct the range on the dipstick could be 5 quarts if it is proportional!
Old Sep 24, 2012 | 11:33 PM
Default Re: dip stick vs. level sensor
Manual says 8.5 qts, so I would carefully add 1/2qt and see what happens. If I lost 1qt in 3,500 miles I would be worried.
I added 8 liters and that took it to the max.
Old Sep 25, 2012 | 09:29 AM
Chris L.'s Avatar
I have been on this forum for about 5 years......I don't recall anyone ever having to add oil between oil changes?
How many miles on your XF?
Old Sep 26, 2012 | 11:34 AM
bieber's Avatar
Does anyone know the range on the dipstick? If that set range "area" is one quart, like the manual says, then I have only used about 1/5 of a quart.
After the oil chage the level was exactly at the top of that range "area" on the stick and it is around 1/5 of the way down from the top of that range "area" now.
Thanks
Old Sep 26, 2012 | 01:48 PM
Ed Mahoney's Avatar
I just put in 8 qts & reads full on dip stick when I do my oil changes !!! Never add any oil either between oil changes !!!
Old Sep 26, 2012 | 02:33 PM
6000rpm's Avatar
You're right about the owner's manual saying the dipstick shows one quart, but my oil changes only need 8 quarts, not 8.5. Maybe it doesn't all drain out. I don't know.
File Type: png
Old Sep 26, 2012 | 06:20 PM
Thanks
After an oil change the level will drop a little to fill the filter and some lines maybe when the engine is run.
Old Sep 26, 2012 | 06:55 PM
8.5 on my SRT's. I drain mine the old fashion way... Top sider's don't always get all the oil out. I drain mine, and let it set for awhile...to make sure it all for the most part drains out.
I will always trust the dip stick over any electronic device...
Old Sep 26, 2012 | 07:54 PM
velociabstract's Avatar
8 quarts here with NO usage in between changes. If I were you, I'd add a little, check, if needed add a little more, check and so forth and so on. If your loosing a quart I hope it's leaking on the ground and not seeping into the combustion chambers.
Les
syfi
Mar 28, 2026 04:14 PM
rampntlion
21
Feb 11, 2019 08:18 AM
Sterling57
Apr 11, 2016 06:11 PM
AlbertFattal
Sep 24, 2015 05:03 AM
lazorouss
Sep 11, 2015 09:16 AM
