Help me find part no. for exterior trimming around windshield
Old Jan 27, 2014 | 06:48 PM
dom03's Avatar
Default Help me find part no. for exterior trimming around windshield
Hi Guys,
I cannot locate the part no. from the parts catalog for the exterior 3-piece trimming that goes around the windshield.
See attached photos, I need to replace this part because someone spilled some drink/substance over my car and stained this piece.
Any ideas what the part number is and where it can be purchased online?
Old Jan 27, 2014 | 07:00 PM
Default Re: Help me find part no. for exterior trimming around windshield
Many on here have successfully repainted the windshield surround. Why replace it ?
A good body shop should charge around $50 - $80, or you can DIY.
Old Jan 27, 2014 | 07:16 PM
shaag78749's Avatar
Originally Posted by dom03
Hi Guys,
Here's the part and part number, but the prices are unbelievable (Numbers 13 and 14 on Diagram)
Ornamentation. Fits: 2004 CHRYSLER CROSSFIRE | FACTORY CHRYSLER PARTS
Last edited by shaag78749; Jan 27, 2014 at 07:18 PM. Reason: provide number of parts
Old Jan 27, 2014 | 07:19 PM
dom03's Avatar
I think I found it - page 206 of 259 of the parts catalog, refers to the Group - EZH Exterior Ornamentation > Moldings and Ornamentation > Fig. EZH-210 > Ornamentation
Items 13 and 14 refer to the upper and left/right MOLDING, Windshield Garnish
I am trying to identify the cost of the item to put it into my police report for claims purposes against the offender (I have their number plate and know who did it). Hopefully I recoup the cost of the damage and get it replaced.
Otherwise I will pull this part off and have it professional sanded and resprayed and a new coat of clear finish, that is the problem, the clear coat finish has started to peel off now.
Old Jan 27, 2014 | 10:39 PM
dom03's Avatar
Anyone got clear instructions on how to safely remove these panels without damaging the clips?
Old Jan 29, 2014 | 09:58 PM
BibaResto's Avatar
Hopefully this will work: HELP - Door handle & windshield trim removal - CrossfireForum.org
It is a link to another XF page and shows where the massive clips are located. I used several screwdrivers. I started at the join where the upper and left side meet. I started on the upper/middle part and slid a screwdriver between the glass and trim part where the clip is, then pushed the screwdriver roughly in the center and twisted it to pop the outer connection. After you go all the way around, then you have a raised ledge so that you can easily put the screwdriver in from the outside and pop the inner portion of the clips. There are three per side and five in the upper section.
A fellow on another thread said he could switch his out in five minutes (he had two sets). I probably took at the very least 45 minutes to remove mine.
Change of subject: Do any of the parts listed on the 'Chrysler Ornamentation' sheet indicate the rubber seal that goes over the front side and top of the side windows? To clarify, the seal the covers the edges of the front and upper portions of the side windows when they're up.
Biba
Old Jan 30, 2014 | 01:20 PM
The clips are metal, so you won't break them. I used a plastic pry bar and got under the edge then just walked down the rest with my hand. I did have the plastic seperate completely from some of the metal clips since it is just 3m body tape holding them on, I just cleaned and prepped where the old tape was and replaced it, should be good for another 10 years
On the side pieces, you can literally just grab them and pull, you will pull harder than you think, but keep in mind, those clips have been in the same metal for years...
Old Jan 30, 2014 | 02:46 PM
Biba
You want the 'Doors and Related Parts' section, Weatherstrips and Seals
Figure DZH-610
Here.
Old Aug 8, 2014 | 11:13 PM
LadyMills's Avatar
Mine has started to bubble and peel off as well. My poor baby looks so ghetto, and I'm not sure how to fix it.
Old Aug 9, 2014 | 12:38 AM
nickwe21's Avatar
Had same issue! Had all parts repainted by a reputable body shop in the same color they were. While they were at it I also had them do my door handles, which had the same peeling going on. Came out like new and was cheap!
That's probably the best fit unless you want to wrap them in vinyl like some members here have done or get Chrome overlays!
Old Aug 9, 2014 | 08:20 AM
LadyMills's Avatar
Yep, my handles look like they got the chicken pox, and my center hubcaps are almost completely rotted off. And the backside of my indoor door handle feels like that plastic coating is peeling off at the seam, too. And last week my headliner startling falling out! What is happening to my poor car?!
What is that crappy plastic coating material they used? Did you have it put back on?
Old Aug 9, 2014 | 08:35 AM
Same thing that is happening to you and me: AGE.
Old Aug 9, 2014 | 12:20 PM
nickwe21's Avatar
Yep, typical age problem I think it depends heavily on where you are located at and whether the car is garage kept or not. I'm in Florida and even though I try to park my car in the shade as much as possible, the sun and salt just gets to it! Since bodyshop painted those parts, the car looks like brand new again and I am very happy about that!
Now if I can only get this stupid door pull fixed, I'll be a happy man! That thing broke off a while back and I refuse to pay $300 for the thing! If you look at solutions for you door handle peeling (happens to a lot of people in here) there is information on how to get it wrapped, perhaps in nice Italian leather!
Old Aug 9, 2014 | 06:59 PM
BibaResto's Avatar
That concerns me about headliners. I've read about the window falling out of roadsters, but not the headliner on coupes.
My XF stays inside unless it is driven. Since SoCal and Texas share the same sun, it is a bear on multiple parts of a car.
And, yes, trees do offer nice shade, but they also have birds who live there, and I swear, they poop on cars just because they can.
Biba
Old Aug 9, 2014 | 10:48 PM
JEFASOLD's Avatar
From the looks of her avatar the age thing is only happening to you. LOL
Old Aug 9, 2014 | 10:53 PM
JEFASOLD's Avatar
Biba
Awhile back there were several cases of falling headliner, This is something a reasonably competent individual can do at home. Do a search, there are several descriptions of the process. I didn't have a falling headliner, mine had a hole in it and it came out great.
Old Aug 10, 2014 | 01:02 AM
LadyMills's Avatar
I've read about a lot of brave folks on here doing their own headliner. While I'm fairly confident (thanks to the wonderful members posting here) that I could do it myself, I am mortified of busting a clip and never finding a replacement.
The humidity down here is so brutal, I'm amazed my car is even running at 163,000 miles. But she has suddenly taken a turn for the worse; kinda like when I hit 45- stuff just randomly started breaking!!!
2004_
Jul 9, 2025 12:39 AM
amx1397
Apr 24, 2025 07:31 PM
stlas69
Sep 3, 2015 10:28 AM
gileyman
Jul 10, 2015 05:59 PM
mike28117
Jul 10, 2015 10:51 AM
