Hood Release
Old Jan 11, 2015 | 03:39 PM
Phil's Avatar
Default Hood Release
Gang,
My Hood Release seems to be sticking (2004 Coupe). The latching mechanism will only "catch" all the way if I push down on the hood after it has been dropped down. As well, the pull handle (inside of the car) has a bunch of slack when the hood is closed.
Any thoughts? Is this as simple as lubricate the hood locking mechanism in the engine compartment?
Thanks …
Phil ...
Old Jan 11, 2015 | 03:50 PM
RED DOG's Avatar
Default Re: Hood Release
Originally Posted by Phil
Gang,
Thanks …
Phil ...
Start by lubricating the hood latch mechanism with a shot of white lithium grease (available at most auto parts stores). Work the mechanism a few times and that should fix the problem. Also if lubing the mechanism doesn't end up taking the slack out of the pull cable, look for an adjustment point on the cable pull to take that slack out. I suggest you take care of this problem quickly before something snaps leaving you unable to open your hood.
Old Jan 11, 2015 | 04:22 PM
Mrmiata's Avatar
Just hit mine a couple weeks ago with Silicon chain lube (motorcycle).. works a whole lot better now and no mess or trying to "get into" mechanism ..
Old Jan 11, 2015 | 06:20 PM
Gang,
Thanks …
Phil ...
Has it always been like this?
Any front end damage from a crash?
Old Jan 12, 2015 | 08:28 AM
Phil's Avatar
Gang,
Thanks for the recommendations. I picked up some silicone grease last night.
No the problem started a few weeks ago. No, the car has never had any front end damage.
Will let you know.
Phil ...
Old Jan 12, 2015 | 12:37 PM
Phil's Avatar
Gang,
Just applied the silicone spray. Worked great.
Thanks for all the help.
Phil ...
Old Jan 12, 2015 | 01:57 PM
Mrmiata's Avatar
Gang,
Phil ...
I'm sold on the stuff for everything "hinge and or cable" related. Unlike WD40 it sticks around a while. LOL
8ighth Wonder
Dec 15, 2015 01:42 PM
Charlesl
Sep 30, 2015 10:46 PM
waldig
Sep 17, 2015 10:35 AM
Vegaslegal
Sep 10, 2015 11:24 AM
RiderJC
Sep 7, 2015 11:19 PM
