Hi I'm new to forum. So hello all !
i have an 05 rag top ltd. had it since March 08. Love it. Never had a problem other then replaced tires. Change oil. Car right now at Chrysler as one day started car and it just kept cranking and had to turn off by turning key to off. Then next day car stalled as I went from reverse to forward. Then decided to go to my tech but car stalled on way. Being that my tech was now 35 miles away as I moved I had it towed to Chrysler (Atlantic). They informed me their "crossfire" tech couldn't take out to check way stalling as he was afraid water pump was so loose. So they need to replace war we pump and then take out as this isn't stalling problem. I have been almost 100 percent assured it's the crank position sensor. They Chrysler still hasn't received water pump and this is 4 days later. My ? Is should I tell them they may want to see about the cps after they replace water pump. Anyone have any ideas or thoughts to add?
Than you to all
Than you to all
on
Re: Hi I'm new to forum. So hello all !
Than you to all
Than you to all
Hello sweetlips! Welcome to the forum! Your going to learn quite a lot from the folks here, about this cult following for quite the set of wheels you have. I would suggest you immediately tell those dealer guys to put your car back on a carrier and take it home. Pay that small bill, I bet you'll be thanking the forum later. A few of the members will chime in with a few more questions, as I just am exhausted and running almost on empty. Sounds like you said the starter was still engaged even after the car was running, and you have to shut it off by the key? Just off the top of my head, that sounds like the starter was not 'retracting' after the engine engaged, making it sound like it was still trying to crank? If this is the case, please confirm. One thing I can say, the water pump has nothing to do with what your describing. Now, if when they opened the hood, and saw something akin to this water pump diagnosis, that's a different story. Anyway, even the water pump is something within the experience level of the forum folks. OK, so lets try to restate the starting issue, add whether or not the water pump was found as a sidebar to the starting issue (remember you may even be able to fix that as a DIY with the correct assistance), and maybe others can jump in to help after clarification. Good luck!
on
Yeah, that's the way its supposed to work. If what the OP is saying is that it continues even after the engine runs, then there is a possible 'disengagement' problem. We'll see if a re-state from the OP clears it up any.
( the little thingey tucked away in the under hood fuse box )
on
Here you go:
https://www.germanautosupply.com/sto...on-sensor.html
On external torx bolt holds it in.
It could be bad gas or fouled fuel injectors, but MANY cars have done similar things and all they needed was a CPS. I'm on my second one now, and have a spare in the trunk. DO NOT order one, order two and have a spare.
on
Bad CPS. $45 with free shipping.
Here you go:
Here you go:
Hope the original poster didn't suffer an aneurism after the stealership presented him with a quote for the repair!!
Once thing I just can't wrap my head around is -
1.) Why is everything at Chrysler so extremely overpriced even a cheap repair (part + labor) such as a crank shaft sensor.
2.) How come Chrysler is not capable of really working on our cars. I mean a skilled professional mechanic should have no problems working on any car be it a Mercedes, Saab or a Ford given access to the service manuals. After all the Mercedes engine is an engine that works on the same principle as others just with better quality and some unique features.
3.) I have been to several Chrysler dealership getting my dad's minivan serviced and every single one of them claims they have a designated Crossfire tech there. Now, I know they had those back in the day but it's been a while since Mercedes and Chrysler got divorced, I would be highly surprised if each of the 7 dealerships in the area have a real Crossfire tech still!!! Why can't they just say "Listen, we don't have a Crossfire tech nor are we comfortable working on this car as it really is a Mercedes". That would actually raise my respect level for them!
WindRestrictor
09-18-2015 05:10 PM
Valk
09-17-2015 11:43 AM
NORDVIK72
08-25-2015 11:43 PM
