Car cut off at stop light
Old Dec 24, 2017 | 02:50 PM
Field's Avatar
Default Car cut off at stop light
Basically I came to a stop then all of a sudden the car died and all the lights came on.Waited a few minutes and it started up like normal.What could be the problem?
Old Dec 24, 2017 | 03:00 PM
Default Re: Car cut off at stop light
RCM or CPS
Old Dec 24, 2017 | 04:01 PM
If you leave the key on and wait 20 seconds:
The engine fan warps up to full speed - RCM's "engine control relay" output is absent, resolder and/or change the EC relay on the RCM.
The engine fan does not run at high speed - CPS
Or it could be a zillion other things, but the above is what is usually is.
Old Dec 25, 2017 | 08:41 AM
Field's Avatar
I have heard the fan cutting completely off when im at idle and sounds like the car will cut off.
Old Dec 25, 2017 | 07:15 PM
Padgett's Avatar
Mine was idling down at stop light until got the shakes. Replaced the MAF and issue has gone away.
Old Mar 7, 2018 | 10:32 AM
XFireCrazy's Avatar
Thanks for this thread guys.
I am having a similar problem. Car intermittently dies when coming down from highway speeds either at a stop light or when traffic stops. Happens about once a month or so, but seems to be getting more frequent. Acceleration is also feeling rough. Feels to me like she is not getting a good air to gas ratio or something. Power is still there for the most part, but feels "stuttery". Definitely not feeling 100%.
I have cleaned and oiled my K&N air filters, did a throttle reset, replaced the CPS and got new plugs/wires. Still having the issue though.
I guess I will check the solder connections on the RCM ECR and possibly get a new MAF.
Feel free to share any other ideas.
Thanks,
XFireCrazy!
Old Mar 7, 2018 | 10:36 AM
My car would die at traffic lights, when heat would build up at the CPS with no air circulation. After a bit the car would start and run just fine. Replaced CPS and fine. The CPS on these cars are in a bad location for heat.
James
Old Mar 7, 2018 | 10:42 AM
XFireCrazy's Avatar
James
Oops. I wrote that I changed out the PCM, but I meant the CPS. Fixed my original post.
Then again, it was a while ago that I replaced that part. I may try another one if nothing else works.
Oh, I also did the throttle reset as well with no luck in fixing the problem. I'll add that tidbit to my original post as well.
ShawnQ
Sep 30, 2016 03:19 PM
a12rag
Dec 26, 2010 08:34 AM
a12rag
Dec 24, 2010 09:19 PM
waylander
17
Jun 10, 2009 10:15 PM
hugoboss
Mar 19, 2007 03:34 PM
