oil: which brand?
Old May 4, 2020 | 01:27 PM
  #41 (permalink)
WD40's Avatar
Default Re: oil: which brand?
This stuff:
Thank you leftover Pizza, I mean Pizza to-go, I mean pepperoni Pizza. Damnit! You know what I mean, Thank you.
Along with 'zero4crossfire's link (https://www.walmart.com/ip/Castrol-E...5-QT/145736795) you have moved some oil off the shelf today!!! And, also, sell your stock in Mobil 1. Yeah.
Old May 4, 2020 | 01:41 PM
  #42 (permalink)
Originally Posted by Longbeach90814
Costco members: sells 5 quarts for $38.69 free shipping
Mobil1 0W-40 is on sale right now at Walmart for $22.88 @ 5 qt ( https://www.walmart.com/ip/Mobil-1-A...fc017e0a0ab7b7 ).
Old May 16, 2020 | 11:08 PM
  #43 (permalink)
Old May 17, 2020 | 01:26 AM
  #44 (permalink)
What Valk said, and bought from Walmart at $23.99 a jug.
Old May 20, 2020 | 05:19 PM
  #45 (permalink)
Vvette's Avatar
LOL, love all the money everyone has..SUPERTEC, half the price and meets/exceeds MFR rec.. Used on all my cars including several Vette's since 2005.. Save your $$$
Old May 20, 2020 | 08:50 PM
  #46 (permalink)
My other two vehicles use ST, I never saw a ST oil that has the MB spec on it yet though. I have a limited lifetime powertrain factory warranty on my 08, would not want to be denied coverage because of some obscure technicality! Wal-Mart Mobil1 0W-40 synthetic for my girl!
Old May 20, 2020 | 10:00 PM
  #47 (permalink)
What good is a lifetime warranty when the expertise and infrastructure no longer exists ?
Old May 20, 2020 | 11:58 PM
  #48 (permalink)
WD40's Avatar
Old May 21, 2020 | 07:19 AM
  #49 (permalink)
Vvette's Avatar
Enjoy and spend. On flip side I never heard a MB as the requirement (not recommendation). As long as its meets/exceeds the Specs which ST does....Ill use it all day long. Too bad I cant get a ST oil filter (I use them on all my Vette's)...Hate Oil companies-they put fear in you..
Old May 21, 2020 | 02:21 PM
  #50 (permalink)
Good question, and I'll find out the answer when an event happens!
Old May 21, 2020 | 02:27 PM
  #51 (permalink)
You are wrong young patawan! The recommended oil for the German built Crossfire, 3.2L motor, DOES have a European spec for the oil (recommendation). You can do whatever you want with yours, I'll spend what and where I want to. You probably bought yours USED, huh? Whole picture here vette guy!
Old May 22, 2020 | 03:30 PM
  #52 (permalink)
For those interested in using Castrol Edge full synthetic 0w40, I found it on Amazon today for $19.31 per 5-qt jug. Pretty good price! Free 1-day delivery if you are a Prime member.
Old May 22, 2020 | 03:44 PM
  #53 (permalink)
Yeah, GOOD PRICE! Does it also ship free if spending over 25 bucks? You do know they have a disclaimer about shipping times @ the virus? Also, I am guessing it is euro spec for MB spec's for the XF?
Old May 22, 2020 | 03:52 PM
  #54 (permalink)
Originally Posted by phil alvirez
from wiki:
The number before the 'W' is the 'cold' viscosity rating of the oil, and the number after the 'W' is the 'hot' viscosity rating. So a 5W40 oil is one that behaves like a 5-rated single grade oil when cold, but doesn't thin any more than a 40-rated single grade oil when hot.
then see post 5. i ended up using pennzoil euro platinum. from the study mentioned at the post, pennzoil does better than mobil. and i think choosing 0 or 5 is not critical after all.
depends mostly of the temps where you are, the availability and offers. what am using is this:
Pennzoil 5W30 Platinum Euro Synthetic Motor
the specs here show several options of the euro for cars like the crossfire https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
0W40, 5W30, 5W40
This is good info describing multi-grade oils. What I like to remember is a multi-grade has a "flatter" viscosity curve versus operating temp than a single weight oil. In other words, with the use of additives, the oil companies can enable an oil to better maintain its viscosity with increasing operating temp.
Old May 22, 2020 | 05:42 PM
  #55 (permalink)
Oil meets the 229.3/229.5 MB Spec. Price may be somewhat normal for this brand/grade. Saw on Walmart's website 5-qt jug was the same price. When I changed the oil/filter on my Coupe a couple of weekends back, I had several quarts of 5w40 Castrol Edge Full Synthetic in my stock. Oil is approved for the VW Beetle (interesting, don't think 0w40 is recommended). Anyway, I used 3 qts of the 5w40 Castrol with the 5-qt jug of Mobil 1 I bought.
Old May 23, 2020 | 01:33 PM
  #56 (permalink)
BobG's Avatar
Ok, let me take a stab at summarizing the engine oil advice:
  • Full synthetic only
  • Meets both Mercedes specifications MB-Approval 229.3 and MB-Approval 229.5
  • Although our cars' documentation specified 0W-40, 5W-40 is an appropriate substitute
  • Use a high quality oil filter (e.g., Mann HU-718/5X)
Based on a bit of reading it appears that the 229.3 specification applied to pre-2005 MB engines and 229.5 applied to 2005 and later engines. There is ambiguity about whether the switch over model year is 2004 or 2005. (And aren't our Crossfire engines pre-2005 MB ones?)
Links to the current MB oil specifications:Note that these specifications claim to apply only to engines in current production. There is also some MB forum chatter about MB oil specifications and paper/non-paper oil filters, but it looks like a rathole.
There are only two 5W-50 oils that meet the 229.3 specification, both are Mobil 1. 5W-50 does not appear on the 229.5 specification, but that might not matter based our engines being pre-2005, though this thinking may not be correct.
[Me: I've been using Mobil 1 0W-40 with Mann filters. When I run out of Mobil 1 a few years from now, I might switch to 5W-40.]
RyanB
Jul 4, 2016 05:59 AM
pizzaguy
May 23, 2014 07:33 PM
boboridesbmx
21
Feb 24, 2012 06:44 PM
eldorado
18
Apr 3, 2011 08:36 PM
MightyMike
15
Sep 10, 2009 01:31 AM
