Question after my first oil change
Old Nov 12, 2005 | 02:41 PM
Aero Blue's Avatar
Question Question after my first oil change
I decided to get the oil changed today, seeing that the FSS now says 900, so why wait any longer. I get it changed, no problem and when I get home I decide to reset the FSS. After a couple tries, I ended up turning it and then 7,000 came up with two wrenches, is this correct or was I supposed to get one wrench. My car has 7,575 miles on it FWIW. Thanks alot guys, just wanna make sure I did this right!
Old Nov 12, 2005 | 07:59 PM
chxf's Avatar
Default Re: Question after my first oil change
7,000 miles seems to be a little low. Had my first service on Wednesday. After, the FSS showed 15,000 km (9,320 miles). Two wrenches means Service B, IIRC. Check your manual.
Greets
Old Nov 12, 2005 | 11:46 PM
AlbertFattal's Avatar
How much do you pay for the 3,000 mile services? About $90?
Old Nov 13, 2005 | 08:00 AM
REDSC400's Avatar
BobS has it correct. The two wrenches informs you that the NEXT service (in 7.000 miles) will be the more extensive "B" service.
It takes a bit of practice to reset the service interval indicator... getting the knack of it is everything. For instance, When the manual says to push the **** twice it does not say to do so QUICKLY.
Old Nov 13, 2005 | 09:43 AM
RickB's Avatar
Originally Posted by bobs
As far as the wrenches go, they tell you which service is due next. One wrench means a service "A" is due. Two wrenches means a service "B" is due. You should have a service log with your car that lists what's required with each service. If you don't have one, there are scanned copies of the logbook on this site. I can't remember who posted them off the top of my head so hopefully the original poster will post us a link to his gallery (hint, hint).
They are at: https://www.crossfireforum.org/galle...00/ppuser/8790
I posted them for several people who didn't get the service log.
Old Nov 13, 2005 | 11:14 AM
ben47's Avatar
Yes, everyone in the U.S. should of received a plastic trifold with the owner's manual, a maintenance log and a warranty booklet. For those that didn't, you can find what is covered in the "A" and "B" service in the owners manual, starting on p. 232.
You did a good job of describing how the FSS counts down and how you may or may not get more/less than 7,000 miles between oil changes. I too have went well into the 9,000 mile range. (This has been debated in length in other older threads and I am of the belief you use the specified manufacture's fluids and schedule service as dictated by the FSS).
Off Topic:
One thing to note concerning the "B" service that I have not seen anyone mentioned in this forum. Although not a critical item, don't forget about the HVAC filter. It's supposed to be changed during the "B" service but I let it slide till I had the car almost two years with 23k on the odometer.
My dealer charged $48.60 for the filter and wanted $27.50 to install it. They have been selling Crossfire's since Aug '03 and didn't even have one in stock. The parts manager said I was the first to request one. I asked why it wasn't on hand since it was a scheduled service item. He said if they used two in a one year period they will keep them on hand, otherwise they have to order it as needed. After it came in I did it myself saving a few $$$ and a second trip to the dealer to have it put in.
Note: I live in a dusty area and the HVAC filter wasn't in all that bad of shape. I don't think you need to do it every "B" service as suggested.
Old Nov 13, 2005 | 01:27 PM
Aero Blue's Avatar
Arrow Re: Question after my first oil change
Thanks alot guys, much appreciated! I read somewhere on here that a guy checked his at 23K and it wasn't even that dirty.
Old Nov 13, 2005 | 09:36 PM
chxf's Avatar
How come my FSS was reset after the A service and showed 15,000 km (over 9,000 miles) to the next B service? Is it possible US versions have shorter intervals than EUR models?
My A service was done at 19,500 km (12,300 miles) when the FSS display showed 0. But don't know anymore at what number it started.
Old Nov 14, 2005 | 06:09 AM
bobs's Avatar
That's a good question! I just had a service B done and the FSS reset to 7,000 miles (11,600 km). I guess it's possible to have different software for each region the car is shipped to. But I can't see why they would do that unless it was some kind of regulatory compliance thing. Only DC knows for sure.
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
xfClifford
Aug 3, 2015 11:03 PM
skeet370
Jul 18, 2015 01:02 PM
