Trunk Lid Jammed
Old Aug 14, 2011 | 06:59 PM
  #81 (permalink)
Default Re: Trunklid Jammed
Thanks, TR and I agree on the Emergency Release cam.
I'm trying to contribute, guys. But sometimes I go too far, too fast. And not only with women, so it seems. (Thought I'd say it before Beaner did. )
Old Aug 14, 2011 | 07:12 PM
  #82 (permalink)
Kola52's Avatar
Would everyone please re-read post 73 and tell me what you think. The additions I made are in RED.
All I can add is, if we hadn't been able to open it through the light, then the only alternative was to let Chrysler do it, and they had quoted me 5 to 6 hours labor at 85 dollars an hour. They were going to take out the seats, take out the back panel, then drill though some rivets to try to open the latch, then "Attempt to open the trunk". I'm sure they were planning on pulling that emergency release as well.
They were pretty plain in the fact that we were paying the labor even if they couldn't get the trunk opened, plus an additional 90 dollars diagnostic charge. plus what ever parts were needed of course.
Mercifully it didn't come to that. My husband said I should drive my car back to the dealership and tell them their mechanic should sign up for this forum!!
Old Aug 14, 2011 | 07:21 PM
  #83 (permalink)
Pizzaguy,there are two photos that show the cable release in the roadster trunk and they both seem to show the cable in a different spot. I will put your revised article in the Index of Crossfire problems but I would like to know how the cable would be hooked in your photo if the right hand tag lite was removed. Maybe I'm missing something.
Old Aug 14, 2011 | 07:33 PM
  #84 (permalink)
I dont get it, either! I'd say to remove the LEFT light! Ask the original poster with the Blue Roadster about it - cause I don't get it, either.
HEY, there is no motor in the blue car - SRT maybe?????
Old Aug 15, 2011 | 09:23 AM
  #85 (permalink)
That's my point, is the cable different in the two models, does the SRT have a different layout for the cable? I would have doubted that, but.....
Old Aug 15, 2011 | 09:48 AM
  #86 (permalink)
hcarter's Avatar
Not sure about the layout on the n/a but on my car srt the cable looped around on the right side of trunk , I don't have a chrysler dealer within 100 miles around me that has a mechanic that seems to know anything about these cars I bought the shop manuals and sat down and started reading , and I understand about the dealers charging a arm and leg and still screwing things up while trying to guess fix a problem ....... I really enjoy owning this car also but dealing with dealers is worse than a sharp stick in the eye sometimes.......This forum is the first and best outlet for info when it comes to problem solving..one could imagine what kind of damage they would do going thru the panel behind the seat thru the top mechanisim ...
Old Aug 15, 2011 | 10:22 AM
  #87 (permalink)
Kodebuster's Avatar
Pizzaguy, no apologies needed, as I've followed this thread closely, and it's one of those must have mods for us Roadster folks...A BIG THANK YOU...
If I did the Emergency Release mod, and the Electric Cam mod, would I then only be at the mercy of a Pneumatic Air Unlock...???
(That's a question...Not a Statement...!!!).
I thought only the possibilities of intermittant Siren issues would keep me awake at nights, I've now added a possible jammed Trunklid to my paranoia...lol...
Old Aug 15, 2011 | 10:31 AM
  #88 (permalink)
I'll ask one question of you, is the cable looped to the right because the handle on the outside of the cover panel is missing? In your case maybe the cover panel is missing as well.
Old Aug 15, 2011 | 11:50 AM
  #89 (permalink)
hcarter's Avatar
No everything was in place nothing missing . the picture does not have the cover on because i was wiring LED's in the tag lights at the time
Old Aug 15, 2011 | 11:56 AM
  #90 (permalink)
Can you see why I am asking this question?
The cable on your car goes in the opposite direction to the cable on Pizzguys.
I do not have a roadster so I cannot check. Your cable seems tied to the hood, Pizzaguys goes to the handle inside the trunk.
Pizzaguy is confused as well.
Old Aug 15, 2011 | 12:02 PM
  #91 (permalink)
hcarter's Avatar
i had my cable completely disconnected from the handle in this picture and the cover completely off ,i stuck it in the hole to hold it out of the way while i was wiring the lights and mounting the capacitors.
Old Aug 15, 2011 | 01:17 PM
  #92 (permalink)
OK, so it is the same as the na as we assumed. Pizzaguy and I thought that you would remove the left hand (D/side) tag light and hook onto the release cable not the right hand cable as you said in this post in "Chrysler Dealership can't open trunk".
Tell them to remove right side tag light use hook tool to pul cable open trunk ...$5.00 please good luck.
I would just like this to be clarified thats all.
Old Aug 15, 2011 | 01:20 PM
  #93 (permalink)
hcarter's Avatar
Right side was correct , thats how i opened mine .
Old Aug 15, 2011 | 01:28 PM
  #94 (permalink)
Kola52's Avatar
This might clarify something (I know I should get my husband on here telling this since he's the one that actually did the work) It wasn't a cable. He said, he pulled the light out, the took a flash light and looked in there. You could see a white (I think he said piece of plastic) accordian shaped (I am assuming something ribbed) thing that you could tell was supposed to slide, the took a screw driver and moved it out of the way. Now I don't know if he pushed it left or right, but i am assuming its obvious, and since it was something you could actually see, I guess you could tell which way it went. Whether that white part is part of the emergency release, the pneumatic lock or the electric lock I can't tell you. I just know, once he slid it the trunk opened!! Oh and I have a 2006 Roadster Limited.
Old Aug 15, 2011 | 01:30 PM
  #95 (permalink)
hcarter's Avatar
Glad all is well
Old Aug 15, 2011 | 01:42 PM
  #96 (permalink)
This must be the part he saw.
Old Aug 15, 2011 | 04:17 PM
  #97 (permalink)
I think it was, 180. See, I took my tag light out, well, off - but the socket assembly would not come out! Seems like it's glued/hard seated in there! I thought the tag light was a dead end, I guess not.
Old Aug 15, 2011 | 08:37 PM
  #98 (permalink)
Kola52's Avatar
That looks dead on. Out of curosity which lock is it attached to?
Old Aug 15, 2011 | 10:16 PM
  #99 (permalink)
That is the electric lock that locks the trunk for the 23 seconds that the top is going up or down. It is NOT the pneumatic lock that operates off the key fob.
The plunger inside the accordian thing does not always retract into the "unlocked" position after the top is done moving - which leads to all sorts of problems! We take off the black end thingy to disable the lock and solve the problem. You cannot simply take the whole assembly out, as it indicates a locked condition to the electronics of the car - enabling the top to operate.
Old Aug 15, 2011 | 10:22 PM
  #100 (permalink)
FIXRE's Avatar
Great info! Just for clarification, remove black part thats in the palm of your hand?
