LET High Stall Torque Converter!
Originally Posted by SRTpowa
Is this just on the LET pullies? I don't recall anyone ever mentioning replaceing the crank bolt with a new one before the ASP install?
Originally Posted by loungn14
The crank bolt on the car is 1 time use only. Once properly torqued it stretches and CANNOT be reused.
x2 The crank bolts are just like head bolts on pretty much all newer cars(past 10 years or so) and are stretch bolts. If you reuse them they can still "work" but most of the time will still be loose when re-torqued.................or will just snap in half.
You know we have a standing mile(and trying to start standing 2 mile) competition here in Las Vegas every September............and there's a 1/4 mile track 10 miles away from that event sight.
What's the name of the track where they run this event? I'll put it on my calander. Las Vegas is much closer trip for me.
They have it at Nellis Air Force Base and it's called the "High Roller Shootout". Last year it was on September 30th I believe as it was right after my birthday.
This talk of stretchy bolts had me thinking. A friend of mine was telling me that the bolts that hold the intake manifolds on are stretchy bolts too and should be replaced if removed.
Can anyone verify that for me?
Originally Posted by Bulldogger
If you are referring to the intake plenum bolts they are set a 7ft/lbs. If they experience bolt stretch at 7ft/lbs I think we have much bigger problems
. answer to question is no
blackpepper
Oct 4, 2017 06:09 AM
