Pulley Saver Kit
Old Sep 20, 2009 | 11:03 AM
  #101 (permalink)
distantpulse's Avatar
Default Re: Pulley Saver Kit
Does anyone have instructions?? I'm not understanding where the third pulley goes.
Old Sep 20, 2009 | 01:23 PM
  #102 (permalink)
NeedsWings's Avatar
sent, call me if you have any other questions
Old Sep 21, 2009 | 10:01 AM
  #103 (permalink)
tom2112's Avatar
She can ride with me ;)
It goes under the hood, up front, near the other pulleys.
Old Sep 21, 2009 | 11:12 AM
  #104 (permalink)
LoL, smartazz!!
Old Sep 21, 2009 | 11:23 AM
  #105 (permalink)
cross><hair's Avatar
Originally Posted by waldig
Iam doing a 185 and have used the bolt head and nut with success, the belt on my 185 IS NOT TOO TIGHT. Between the s/c and alternator I can push down the belt 1 or more inches with a finger with moderate pressure, (deflect the belt). Woody
Too tight kills accessories and their shaft bearings............
Hmmm, that worries me. Mine is pretty tight- I don't have that kind of movement on the belt with "moderate pressure".
Old Sep 21, 2009 | 12:06 PM
  #106 (permalink)
MikeR's Avatar
Woody might have a 'moderately' bigger arm than you.....
Old Sep 28, 2009 | 07:57 PM
  #107 (permalink)
TemjinX2's Avatar
i just installed my pulley saver kit. I think the coolant lines on the srt6 run slightly differently then the c32. The pulley near the alternator runs dangerously close too the coolant lines, another c32 owner claimed the belt rubbed on his coolant line.
You can fix it if you raise the coolant lines coming from the intercooler a little but then the coolant line is touching the intake valve cover.
I didn't like the idea of the engine heating the coolant, so i use the alternator pulley from the code3 belt wrap kit and it was the perfect size.
Just a word of caution for the c32 owners out there.
Old Sep 28, 2009 | 08:22 PM
  #108 (permalink)
TemjinX2's Avatar
here some pics i took. i'm using the code3 alternator pulley which is smaller then the pulley saver one.
Old Sep 29, 2009 | 06:08 AM
  #109 (permalink)
waldig's Avatar
Talking Re: Pulley Saver Kit
Your belt layout is closer and thus an issue. I had my belts back and supported to avoid any contact due to belt flap or resonances in the belt. Woody
Photos are of my inital workup of the support brace in 2008, I now have the stainless polished bar, w/o rust hee hee
Old Sep 29, 2009 | 06:23 AM
  #110 (permalink)
TemjinX2's Avatar
well the code3 alternator pulley is working out well. I might relocate my coolant lines in the future to run the larger pulley saver pulley in the future.
But my main concern was getting rid of the supercharger idler pulley. I went through two in the last 6 months. I like the idea of the larger slower moving idler pulley.
Old Oct 2, 2009 | 02:22 AM
  #111 (permalink)
NeedsWings's Avatar
can u use a large zip tie to pull the coolant lines over 1/2 an inch for better clearance?
Old Oct 2, 2009 | 02:42 AM
  #112 (permalink)
TemjinX2's Avatar
yeah, someone already posted the work around.
TemjinX2's pulley Saver kit review - MBWorld.org Forums
Old Oct 2, 2009 | 09:57 AM
  #113 (permalink)
MikeR's Avatar
TemjinX2, you must have changed your hoses or routing. The factory routing runs behind the pulley to the passenger side. I couldnt figure out why you were having problems and went and looked at mine. My hoses dont even come over the pulley. I separated my IC cooling but didnt change any hose routing except the overflow line and feed into the top of the coolant tank.
Old Oct 2, 2009 | 01:41 PM
  #114 (permalink)
TemjinX2's Avatar
Originally Posted by MikeR
TemjinX2, you must have changed your hoses or routing. The factory routing runs behind the pulley to the passenger side. I couldnt figure out why you were have problems and went and looked at mine. My hoses dont even come overe the pulley. I separated my IC cooling but didnt change any hose routing except the overflow line and feed into the top of the coolant tank.
My hoses are stock...keep in mind, i have a C32 not a srt6. I believe the c32 hoses run slightly differently then the srt6.
Old Oct 2, 2009 | 08:13 PM
  #115 (permalink)
jturkel's Avatar
rob. you have an email. my pulley bearing went out today and need your kit asap
- josh
Old Oct 5, 2009 | 08:23 PM
  #116 (permalink)
jturkel's Avatar
ordered! cant wait to install b/c idler bearings going bad!
rob, you get my order?
Old Oct 5, 2009 | 08:27 PM
  #117 (permalink)
NeedsWings's Avatar
you know it, be there wednesday, working on tracking number emails now
Old Oct 5, 2009 | 08:57 PM
  #118 (permalink)
jturkel's Avatar
email received! thanks as always Rob! your help and communication are much appreciated!
Old Oct 10, 2009 | 05:46 PM
  #119 (permalink)
jturkel's Avatar
for some reason, after only 5 months, my middle idler pulley (LET idler with upgraded bearing) was going out. replaced my pulleys with this kit. very impressed with the kit and no longer concerned about bearings going out.
thanks to Rob for lots of help with the install, providing pics, detailed instructions, and even a phone call....not to mention quick shipping (2 days)
i recommend this to anyone! thanks again rob!
Old Jul 6, 2013 | 01:47 AM
  #120 (permalink)
JesseJamessrt6's Avatar
Originally Posted by 32krazy!
thanx woody. jturkel will be glad to hear that.
MikeR sent me the simple solution. add a nut to the pulley nut as a jamnut! did it countless times on my harley. should have thought of it myself!!
Digging up the past here,
What size jam nut is this exactly?
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
