*Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
As Jim stated their list was in a different order. Basically, when he called to run the cards in Nov time-frame, the order in which he was able to make contact and run the cards was how his list was assembled. I sent him everything I had and he would try to send them out in the right order. I never got all the names matched up to screen names, so some are bound to be off. However, like Jim said, they are all shipping in a pretty short period... so please bear with us.
Also, I have 1 last name that is not matched to their screen name. Please send me a PM so I can finish the list:
Alan Jones
Alan Jones
For what it is worth, my two can be last....I'm still trucking, and won't get them into the shop until after the 4th of July...I have a car show that week....just sayin'.....I need to call Devin.....anyway, so I will do that tomorrow and tell him the same thing....hopefully get started on them both mid-July in time for a test run to Detroit for the Woodward Dream Cruise and some consultation with Rob to finish these babies once and for all...
Originally Posted by velociabstract
I guess I can expect mine before Christmas after all. I think this is the last time I buy something that is not on the shelf already. I sure hope the Wavetrac is worth the __________ I feel we've been subjected too. If it's incredible, all will be forgiven.
Les
Les
I'm with you on how frustrating this has been. However, without each and every person on this list, this project would have failed.
Thanks to each and every person here that ponied up parts for R&D, deposits, etc and endured the last year of waiting to make this happen!
jim pm sent to you.
alan i do appreciate all the effort you have put into this. if theres anything i can do on this end to get it to you just let me know.
btw anybody sending their diff to unitrax you will want to include a set of axle seals with your diff. they need them for the install
Also, I have 4 names that are not matched to their screen name. Please send me a PM so I can finish the list:
Alan Jones
Bryan Tracy
John Kolevski (standby list)
Alan Jones
Bryan Tracy
PM Sent.... I also can be at the end if others need theirs faster. I still have kinks to work out in my turbo tune.
Bryan Tracy
Bryan Tracy
Originally Posted by 32krazy!
jim pm sent to you.
here is the post about Devin installing the wavetrac into your diff.
how do u want to work it for those people that want you to install the wave-trac into their diff. at your shop.? what is the cost for that install?
answer Monday. ----Answer-- tentatively the cost is $225.00 + two axle seals + shipping both ways (((Drained please)))
I thought that he had seals on-hand and was just going to charge for them...
Nonetheless, I ordered my gears from this place and had them sent straight to Devin: http://www.oediscountparts.com/partl...layCatalogid=0 OE Discount Parts
and the OEM part# 05114258AA
Nonetheless, I ordered my gears from this place and had them sent straight to Devin: http://www.oediscountparts.com/partlocator/index.cfm?action=getJointLocator&siteid=215242&cha pter=&Sectionids=23,0&groupid=10047&subgroupid=600 92&componentid=0&make=67&model=SLK Class&year=2002&graphicID=F344080&callout=4&catalo gid=1&displayCatalogid=0 OE Discount Parts
Do we need to send gears?
Do we need to send seals?
If so, someone please send me some part numbers for both... and Buggin, isn't yours a C32? Is yours a little different from the SRT-6?
You dont need to send any extra gears... Buggin bought a used pumpkin with no internals(?) and also a ring and pinion so they could install the Wavetrac and he could just swap it out when he gets it....I think
I found a complete diff just a few minutes from Unitrax and had them deliver it for the install.....
I bought a brand new SRT diff from a forum member that told me it was an SRT diff. It ended up being for an N/A, so the gearset was a 3.27. I decided to just buy a new gearset to convert it while installing the Wavetrac. This will give me a completely brand new LSD diff!
Jim, can you verify with Devin that people need to SEND seals? I'm 99% positive that he said he has then on-hand and will add the cost to the install.
Originally Posted by tom2112
Uh... now I'm confused.
send your pumpkin and seals,, OEM part# 05114258AA,, seals part number,,you can get the seals at a dealer or here,,supplied by Buggin ,, thank U ,,,,,,,,,,,ok here ,,http://www.oediscountparts.com/partl...layCatalogid=0
Just talked to Devin. (He called me.)
And he said that SRT-6 folks do not have to send seals. If you do not send seals, he has them and will charge $6 (and change) each seal (two) and simply add that onto the fee for the install.
