62mm SRT6 Pulley Available Now
Old Nov 3, 2012 | 05:21 PM
  #221 (permalink)
Default Re: 62mm SRT6 Pulley Available Now
just heard from a friend that a guy that is not on any of our forums That we know of (crossfire,slk,mbworld,or benzworld.) has a c-32 with a aluminum SC pulley ,, it Exploded pieces went through the hood and through the thermostat housing,, ... hope he post somewhere so we can get some good info. jim
Old Nov 3, 2012 | 05:29 PM
  #222 (permalink)
Originally Posted by crfire001
C32 with few custom modifications. Intake, sc pulley, custom exhaust etc. Mostly I write on my country specific mb forums but read regularly international forums.
My need for new pulley is not immediate since winter has landed here in the arctic circle and car is in the garage for 4 - 5 months. I will consider ordering the pulley. Thanks for the information.
Sounds like you are an international buyer. I just recieved mine. I will be installing it very soon, just waiting to get the 100mm tensioner puilley from Needswings. Might as well do them both at the same time. This was from the pulley saver kit which contained the wrong size pulley. Nothing to do with the 62mm pulley. I will just say this, this pulley is well built, and I have no doubts of it's performance since it has already been tested for months and many miles....I would get one now, as it is limited as we speak. You never know what the future will bring on a new product. I will vouch for the maker and marketeer...
Old Nov 3, 2012 | 05:33 PM
  #223 (permalink)
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Yep...got mine delivered to Canada last night. Very well built, very similar to the OEM pulley .....but alot smaller
Can't wait to try it......in Spring 2013...... God willing that is.
Old Nov 3, 2012 | 05:35 PM
  #224 (permalink)
Knowing you, you better install now....don't wait for 2013...lol....
Old Nov 3, 2012 | 08:02 PM
  #225 (permalink)
My bet is the pulley flange with the rivets in it got fatigued and tore off in pieces.All the torque is transmitted through a thin band about 3mm (.12") thick. Three small rivets transmitting all that power.
Remember the pictures of the aluminum water pump pulleys a few years back.
It's also possible that the pulley itself it may have split into two parts as one part with the belt on it is unsupported for three grooves. The corner of the bearing pocket falls under the third groove from the back and there is not much meat there.
Aluminum is quick and easy (cheap) to machine, I see no benefits in its use in these situations.
Old Nov 3, 2012 | 08:30 PM
  #226 (permalink)
Could someone post the bearing type used in 62 mm pulley?
A previous thread said the outside diameter (D) was 47mm. The internal diameter is the same as the OEM one and therefore (d) is 32mm. By my estimate the spacer washer shipped with this pulley is 5mm thick.
So we have 32mm x 47mm x 18mm. that would be Nachi #
32BG04S3G-2DL available at bearingsdirect.com for $23.59.
or
NSK#32BD4718DUK available at Bearing Source
for $21.70
OEM SC pulley bearing.
32
mm x 55mm x 23mm.
NSK #32BD45DU or 32BD45DUM, available at BearingSource for $15.40
or
Nachi #32BG05S1- 2DST
Available at bearingsdirect.com for $20.49 and
Amazon Amazon
at $28.53
These are double row, angular contact ball bearings grease filled for auto air conditioners.
Idler and tension pulley bearings.
Good for 15,000 rpm.
#6303DU or #6303DDU
Available at bearing-source.com
Or
For #63032RS or 6303ZZ try bearingsdirect.com
Better bearings are from the SKF range. SKF 6303-2RSL and SKF 6303-2Z, good for 17,000rpm, these bearings are sealed on both sides.
The highest RPM rated bearings (22,000rpm) are sealed on one side, SKF 6303-Z or SKF 6303-RSL if you can find them. If a bearing is sealed on one side only it is easy to clean it and repack with a suitable grease at regular intervals to get extra life out of it, the grease gets thrown out during operation. Put the seal towards the front of the car and hope that not too much crap gets around the back. Using double sealed bearings is best.
These bearings are limited by the speed that the seal can withstand. An unsealed bearing (6303) can do 22,000rpm and the fastest sealed bearing have non contact seals.
These are all single row, deep groove ball bearings, grease filled.
Last edited by onehundred80; Dec 10, 2012 at 01:57 PM. Reason: Edited for extra contant
Old Nov 3, 2012 | 11:22 PM
  #227 (permalink)
cjw's Avatar
cjw
Got to test out the pulley.. 7.7 was my best 1/8th mile. My previous best with the 65 was 7.8 only difference is I was running the tcu tune which helped a lot. I definetly need the belt wrap kit and will get that done this week, then install my manifolds and get some better times.
Old Nov 4, 2012 | 06:37 AM
  #228 (permalink)
velociabstract's Avatar
Informative blurb, when I went from my Code 3 65 mm to a 178 and Needswings manifolds my AFR's went from 11.8 at redline to 13. If you don't retune, at least run 100 at the track. I ran at 13 to 13.5 at the 1/2 mile and for a few weeks WITH 100 octane with no ill results. Expect to be around 13 AFR.
Les
Old Nov 4, 2012 | 07:15 AM
  #229 (permalink)
cjw's Avatar
cjw
Les
I was running high octane last night and do plan on a re-tune from EC, just wanted to see what the difference was between the 65 and 62, hopefully the re-tune and larger pump will keep it from being lean on the top
Old Nov 4, 2012 | 08:18 AM
  #230 (permalink)
The manifolds lean the mixture in the entire RPM range at WOT. I was seeing around 13 from 2500 rpm and up.
Les
Old Nov 10, 2012 | 06:55 PM
  #231 (permalink)
JesseJamessrt6's Avatar
SC pulley installed with PSK with updated 100mm pulleys all the way around. No belt slippage and man what a difference! Pulley looks really nice and is smooth as could be. Thanks Rudy and Rob
Old Nov 10, 2012 | 08:02 PM
  #232 (permalink)
rcompart's Avatar
Glad everyone is enjoying them.
Take care
Old Nov 10, 2012 | 09:54 PM
  #233 (permalink)
Leptronjohn's Avatar
Default
Mine has been updated to 100mm all round, it did take care of a bit of slip I heard.
Rob and Rudy are on my list of good guys.
John
Old Nov 11, 2012 | 12:34 PM
  #234 (permalink)
I put off looking at a potential night mare of destruction under the rear for installing more horsepower instead.........
Old Nov 20, 2012 | 08:48 PM
  #235 (permalink)
itsky's Avatar
Rudy,
As discussed at the Dragon, I'm going to be very interested in the pulley here very soon. Also, I've gotten away with not having a PSK with the 65mm pulley, but I assume that I will probably need one with the 62.
Old Dec 1, 2012 | 08:53 AM
  #236 (permalink)
For those that are now running this pulley, please post your impressions and detail if you have retuned for the pulley, and if you have had to overcome any AFR issues etc.
Thanks.
Old Dec 1, 2012 | 11:14 AM
  #237 (permalink)
putting on the new fuel pump today, and then will be waiting to hear from EC for a retune...she leans at 5000....so no more runs until tune....
Old Dec 1, 2012 | 11:21 AM
  #238 (permalink)
grip grip's Avatar
The pump will fatten it up, so you might not need a retune right away. I'd log a 3rd gear pull and let off if you see 13's on the gauge. If you don't see 13's or higher, finish the run and have your retune based on the datalog. Just food for thought.
Old Dec 1, 2012 | 02:22 PM
  #239 (permalink)
dinasrt's Avatar
What fuel pump did you choose for replacement Doc? This is on my to do list this winter.
Old Dec 1, 2012 | 05:42 PM
  #240 (permalink)
