Crank case vent hose
Old Feb 15, 2013 | 08:41 PM
rtcarlin's Avatar
Default Crank case vent hose
Ran across an interesting predicament yesterday. A month or so ago, I noticed the crank case vent hose was torn at the end that connects to the intake.
I removed the driver's side intake as well as the damaged hose.
I consulted my trusty parts diagram and chose item #6.
Ordered it and received the new part. Looks just like the one in the diagram, but nothing like the part that's on the car. Bends are wrong and it doesn't fit (too long).
Original Hose
New Hose
The part numbers match up and the hose looks the same as the one in the diagram, but nothing like the original. I checked the parts diagram for both the NA and SC models and they were the same.
Any ideas on why there's a difference between the diagram and the actual motor? This is on an '05 SRT Roadster.... Thanks in advance!
Old Feb 15, 2013 | 09:08 PM
Default Re: Crank case vent hose
Original Hose
New Hose
The diagram is for the NA and the hose goes down to the venturi at the top of the throttle body. But the SRT one just goes to the intake as you show.
I'm just going from memory of myNA.
Old Feb 15, 2013 | 09:13 PM
rtcarlin's Avatar
I was wondering about that, but saw that under the "Engine" column, it listed EGZ as well. Any help with the proper diagram would be greatly appreciated. I found the diagram under the section entitled "Group - 3.2LS Engine 3.2L SOHC 18 Valve Supercharged V-6 [EGZ]".....
Old Feb 15, 2013 | 09:35 PM
The parts list for 2004, 2005 and 2006 basically list and show the same parts for the NA and the SRT. They just added the SRT model but used the NA diagram and part numbers. I looked for the Mercedes part number but I have not found it yet.
Old Feb 16, 2013 | 06:14 AM
Take a look at this page and see if any of these look right to you :
Discount Auto Parts and Accessories - PartsGeek
Old Feb 16, 2013 | 11:45 AM
In any configuration, can the hose you bought be spun/flipped then cut to be close enough to fit? Just a thought.
Old Feb 16, 2013 | 12:27 PM
rtcarlin's Avatar
It's pre-bent, rigid, and the ends are both flared to facilitate the connection. I've got the original back on fairly secure thanks to some stretchy black tape around the end. I'd really like to use the right hose for the job, rather than just be "good enough"...
Of course, I'll no longer need the hose once I get the Needswings CAI... Just about have the wife talked into it....
Old May 15, 2013 | 10:03 PM
Timesnow's Avatar
I do need this hose, just noticed mine is cracked in two spots. Anyone find the MB part number?
Old May 16, 2013 | 10:10 AM
robby363's Avatar
The MB part# on the hose is 112 018 0782 it was superseded with 112 018 1882 HOSE. CYLINDER HEAD COVER; Hoses; INTAKE MANIFOLD. Mercedes # 1120181882, 1120180782
Old May 16, 2013 | 10:30 AM
I was looking for the one I took off when I put the CAI on, I thought it might have the part number molded into it. Most every other part has the number on it, the Germans are very thorough, ja?
Old May 16, 2013 | 06:04 PM
dinasrt's Avatar
Have you considered getting a catch can from Needswings? http://www.needswings.com/ProductImages/cc1.jpg
Old May 16, 2013 | 08:55 PM
Timesnow's Avatar
New Bie so please bare with me, what does the catch can do for me?
Old May 16, 2013 | 10:41 PM
dinasrt's Avatar
NeedsWings Crossfire Oil Catch Can Kit
This explains it really well.
Old May 20, 2013 | 11:01 AM
Buggin's Avatar
A couple things to point out as I read through this post:
1) A catch can setup does not eliminate the cracked hose in question (item 6), it eliminates items 4 + 5.
2) A DCAI setup from Needswings does not eliminate said hose either (at least not the version I bought from them)
Old May 20, 2013 | 11:33 AM
The single CAI does eliminate that hose, either that or I have to find somewhere to put the hose that sits in my removed OEM parts box.
That's the hose that goes to the rearward DS rocker cover nipple. On the SCAI it is replaced with a hose that goes to a nipple on the intake at the bottom on the PS.
Old Apr 28, 2017 | 06:05 PM
gman's Avatar
This seems to be a right kit to replace all the breather hoses and the price is good:
Engine Crankcase Breather Hose Kit CRP ABK0131 fits 98-05 Mercedes E320
Old Apr 28, 2017 | 08:08 PM
I've found that Pelican Parts has one of the better selections of molded cranckcase breather hoses for the Crossfire/M-B cars. Go to Pelican Parts and search using a 2004 Model Year Mercedez-Benz, then select the SLK series. Click on the SLK32 AMG. Once you're in, go to Engine / Oil Circulation / Cranskcase Ventilation. The only hose shown looks like the one you're looking for. (See attached file)
All the other molded hoses typically needed are listed under the SLK320.
Old Apr 29, 2017 | 05:35 PM
GREAT price for all 4!
Hmmmm, one hose 31 bucks, all 4 for 25 bucks with free shipping? Any reason not to get the full set for @ 25 bucks? I would ask someone who bought these, to post here if they are all the right sizes...
Old Apr 29, 2017 | 05:52 PM
You have to pay to get the OEM hose, the rest are copies. Pelican lists those by the clone makers or OEM in some parts.
If you want the Chrysler part you can always go to the stealer and ask for the part, then you will receive the Mercedes OEM part at a greatly increased price with the Chrysler sticker showing you the Chrysler part number stuck over the Mercedes label which has the Mercedes part number on it.
You could buy the $25 set from China but the stealers kids want to go to Harvard and learn where their father is losing money by not charging more for his services.
Old Apr 30, 2017 | 10:53 AM
I sometimes wonder where MB actually get their hoses from. Does anyone REALLY know? Maybe, the MB part (re-labeled and sold by FCA), is a china knockoff in a MB box before it is labeled a MB part...
Valk
Jul 12, 2021 09:49 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
Sep 25, 2015 02:16 AM
