Threw my Belt again in my SRT6
Old Dec 5, 2015 | 07:31 PM
UNDER PSI's Avatar
Default Threw my Belt again in my SRT6
Thanks ..............
Old Dec 5, 2015 | 08:07 PM
dinasrt's Avatar
Default Re: Threw my Belt again in my SRT6
Any evidence of water or oil leaks? OEM belt, or how many miles on the car or belt? This happened to me when pushing it hard at an autocross, but it turned out that I had a pin hole leak/crack on the return coolant line to the coolant reservoir. Actually it was at the plastic tee at the passenger side of the radiator. When it got hot, or tossed and torqued around(not sure)it apparently spritzed the belt enough to jump off when near WOT. I don't know if it jumped off approaching WOT, or upon the subsequent and sudden deceleration. Anyway.... No trouble since I replaced the plastic tee with a brass one. I was lucky not to sustain any damage what so ever, but could have been serious bad news! Take it easy until you get it figured out. Also, if you end up getting a new belt; placing the serpentine belt is super easy with a long breaker bar and torx socket for the belt tensioner(less than 5 minutes).
Old Dec 9, 2015 | 12:11 AM
Zoodust's Avatar
Originally Posted by UNDER PSI
It happened again, I was powering out of a turn, hit the gas ,tires spun a bit ,and sure enough I Threw the Serpentine Belt fir the 2nd time, Car is a beast, but I can't have this happening whenever I do some spirited driving, AAA got me a flatbed and towed it to Dealer who will reinstall belt on Monday, That's it for now
Ive been in the exact same boat.. either get a whole new belt.. or if you have an aftermarket pulley get a PSK kit from Needswings to reduce slippage.. or also keep a tensioner bolt and wrench to fix problem. Takes 5 min and some muscle to slip the belt back around the pulleys
Old Dec 9, 2015 | 12:42 AM
UNDER PSI's Avatar
Thanks all
Old Dec 9, 2015 | 12:47 AM
UNDER PSI's Avatar
Ok ......................
Old Dec 9, 2015 | 06:47 AM
Do you feel any binding when you rotate the tensioner ?
Could be that, or perhaps an idler bearing throwing a hissy fit.
Old Dec 9, 2015 | 06:49 AM
waldig's Avatar
Talking Re: Threw my Belt again in my SRT6
Be sure that all the pulleys are in alignment and the one is not cocked or offset. Take a long look at the lay of the belts to see one is not too far front or back. Enjoy. Woody
Old Dec 9, 2015 | 07:12 AM
^^^^ Yes.
The crankshaft pulley has been known to creep forward.
Old Dec 9, 2015 | 07:59 AM
Egodriver71's Avatar
Dealer charges $94 to reinstall belt
Better start learning how to do it yourself at that money.
That's highway robbery since you still have the belt
Old Dec 9, 2015 | 09:08 AM
MiamiTVR's Avatar
That takes some fun out of hitting the gas.
While my modified SRT6 has been trouble free I once had that problem with a modified Jaguar. I had to replace belts more often than change the oil. It turned out to be a very slight misalignment with the AC pulley (or deflection upon acceleration or engagement, I forget).
Looking at the belts while running might help. It seems that was how I tracked it down on the Jaguar.
Good luck.
Old Dec 9, 2015 | 09:24 AM
No sign of any leaks wetting or greasing up my belts or pulleys
I see the tensioner assembly was replaced, so I think that possibly the belt is too long and there is not enough tension on the belt. The reason I think this is because yor problem seems to have started after the smaller SC and other pulleys were put on the car.
Old Dec 9, 2015 | 07:10 PM
JEFASOLD's Avatar
Ditto! Again self inflicted wounds. Look at Tighed1s belt wrap solution for a cheap fix. Here is my modified version.
Old Dec 10, 2015 | 12:48 PM
boostmonkey's Avatar
Default
Does your belt show any signs of damage? When I was figuring out the pulleys for my stacked setup, I found the belt around the tensioner would sometimes contact the belt around the PS pulley and ruin the belt. Under load the belt stretched enough to move the tensioner enough that the clearance was insufficient.
Old Dec 13, 2015 | 01:09 PM
Tahoe's Avatar
As said earlier check the crank pulley (harmonic balancer). Just had the same problem and noticed that the crank pulley is slipping forward. Ordering new the tool, harmonic balancer, and crankshaft bolt this week. This is a known problem and should be fixed ASAP before the pulley comes off and does serious damage.
Old Dec 13, 2015 | 01:30 PM
JEFASOLD's Avatar
Originally Posted by boostmonkey
Does your belt show any signs of damage? When I was figuring out the pulleys for my stacked setup, I found the belt around the tensioner would sometimes contact the belt around the PS pulley and ruin the belt. Under lead the belt stretched enough to move the tensioner enough that the clearance was insufficient.
If this question is directed to me, the answer is no. Cutting the grooves off the idler pulley ensures enough clearance between the closest points.
Adrian_X
Apr 30, 2017 10:58 PM
Kowmander
Dec 5, 2015 08:36 PM
pioneer4x4
Dec 4, 2015 10:03 AM
Travish
Nov 30, 2015 04:08 PM
JEFASOLD
Nov 6, 2015 12:45 AM
