5 Degree C Fan Mod
Old Apr 21, 2016 | 12:46 AM
boostmonkey's Avatar
Default
I had to redo my wiring to make the IC pump run all the time. I installed a switch to activate the relay and run the pump, but the ECU sees something is wrong, lights the cooling light, and disengages the supercharger.
Now I ran power directly to the IC pump from a new inline fuse connected to the 12v ignition switched terminal in the bottom of the fuse box. Works great, IC pump runs all the time now, thanks for asking about that Morphh.
I used to run 2 heat exchangers, but now I have the supercooler from Needswings.
Sweet2002, Phil from Eurocharged told me that they could not change the fan setpoint with a tune. Thus I ended up paying the dealership to do it
Old Apr 21, 2016 | 09:58 AM
Morphh's Avatar
Default Re: 5 Degree C Fan Mod
U see any difference with -5 fan mod?
I'm going to check my IC pump. ec told me they made it run all the time with there tune.
Old Apr 30, 2016 | 10:45 AM
Morphh's Avatar
Any difference with -5 fan mod?
Old Apr 30, 2016 | 01:04 PM
IMO, -5C is a waste of time.
I did -10C which is -18F - worth it no matter the cost (which was $50 in my case).
Old May 3, 2016 | 03:11 PM
Default
I have been to the track twice. Ran 12.3s with the exhaust cutout closed and 12.2s with it open. My starting intake air temps were definitely lower, strangely, pretty much exactly 5 degrees C lower. I did not expect the change to correlate so closely with the coolant temperature.
I did not have my IC coolant reservoir installed. I had removed it for a very pleasant road trip in the mountains of North Carolina I took with my wife. That affected IAT a lot too. Comparing my data logs to prior runs, the IAT was stating 5 degrees C cooler, but ending 11 degrees C higher than before. 38 C to 74 C. That tank makes big difference. 43 C to 63 C would be typical before. It is back in now, but no logs yet.
Old May 3, 2016 | 03:15 PM
Default
It isn't a big difference. Your fan will come on at 83 C, but the thermostat will remain closed and the engine coolant will continue to warmup to 87 C. With the lower setpoint, your fan will run faster and cool the IC coolant a little more. But it will run very loudly on hot days.
Old May 5, 2016 | 04:53 AM
Sweet2002's Avatar
I had EC give me another degree of timing and they said my original tune had cooling modifications(?) done to it, what they claim to have done I don't know. I have my car for sale but will continue to mod as I go along as it seems selling is always opposed to buying. I have always liked the '88/'89 Chrysler Conquests and they are now going in the mid teens when being sold!!! 188HP and really dogs. Oh well
tageier
May 30, 2013 05:53 PM
