Catch can with a catchy appearance
Old Mar 23, 2012 | 08:53 AM
  #61 (permalink)
maxcichon's Avatar
Default Re: Catch can with a catchy appearance
Originally Posted by alaxfire
Buy Rob's and paint it RED, then you have function and bling .....
( I'll sell you mine for $200 painted red with a Fred's spray can )
Uhhhh....pass.
But, thanks. Buddy!
Old Apr 5, 2012 | 08:17 PM
  #62 (permalink)
maxcichon's Avatar
Check my gallery.
Old Apr 5, 2012 | 09:51 PM
  #63 (permalink)
Mrmiata's Avatar
Looking good.. now I guess the true test is how much you accumalate in it between oil changes. Looks like that one doesn't have the drain valve? Not that I could see anything wrong with a 7 thousand mile service interval for cleansing or replacing the filter media..
Old Apr 6, 2012 | 06:17 AM
  #64 (permalink)
maxcichon's Avatar
It has a drain valve on the bottom. And I removed and plugged the "Sight Tube" holes-friggin' useless. A shunt around the media? Why?
Old Apr 6, 2012 | 07:32 AM
  #65 (permalink)
JesseJamessrt6's Avatar
Yes, that catch can looks like it will do the job. Did you use a punch press for the baffle, looks clean and well thought out.
Old Apr 6, 2012 | 08:40 AM
  #66 (permalink)
maxcichon's Avatar
Thanks! I used a small precision punch set (E-Z Punch Pak). 1/32" 6061 T-6 Aluminum.
If you're asking about making the 2.66" blank, I scribed accurately with a divider, cut to size with a shear and used a belt sander to make them round. Damned nice fit. I think you can see that?
~ $30 in it and ~ 2 hours work. Made enough parts for a friend! I still have to make a bracket for mounting, but already have a sketch for it. 10 minutes. Plus painting...
Old Apr 6, 2012 | 10:07 AM
  #67 (permalink)
turbomar's Avatar
Looking good max.
Old Apr 6, 2012 | 10:37 AM
  #68 (permalink)
maxcichon's Avatar
Originally Posted by turbomar
Looking good max.
Thanks! I do what I can with what I have.
Or can steal!
Old Apr 6, 2012 | 12:36 PM
  #69 (permalink)
I can see that
You can also see the handy work for the baffle spacers.
How hard was it to fit your inlet tube in and down through the existing inlet nipple? Did you find an exact O.D. to match the I.D.?
Looking forward to seeing your mounting bracket too.
Old Apr 6, 2012 | 12:42 PM
  #70 (permalink)
maxcichon's Avatar
I found 7/16" aluminum "easy-bend" tubing. I had to bore the fitting ~ .015" bigger to get it to slip fit.
Did you notice that I swaged the end larger to catch the counterbore in the fitting? Hmm? It won't move...but it's not helium leak-tight.
Darn.
When I get it mounted, I'll add to the pictures and poke this thread.
Thanks again!
Old Apr 6, 2012 | 12:55 PM
  #71 (permalink)
yh your swag was a nice touch
Old May 25, 2012 | 08:21 AM
  #72 (permalink)
maxcichon's Avatar
A couple of brackets, and voila!
Old May 25, 2012 | 09:37 AM
  #73 (permalink)
Looking good Max, but it would look better on a graphite metallic coupe
Old May 25, 2012 | 09:46 AM
  #74 (permalink)
maxcichon's Avatar
J.,
it just so happens that I made an extra set of brackets for this setup. I had to make sure they fit first, doncha' know!
But I feel that the red would clash, don't you agree?
Old May 25, 2012 | 10:14 AM
  #75 (permalink)
J.,
On a graphite coupe, one word : SILVER
Old May 25, 2012 | 10:36 AM
  #76 (permalink)
maxcichon's Avatar
Not this time: Black its gotta' be. Matches the hoses, too!
Old May 25, 2012 | 10:54 AM
  #77 (permalink)
BLACK ! BLACK ! tighed1 where are you when we need you
Old May 25, 2012 | 04:01 PM
  #78 (permalink)
turbomar's Avatar
Nice work Maxcichon. I still havent had time to stuff mine yet. However, it still catches oil vapor, just not efficiently yet
Old May 25, 2012 | 07:20 PM
  #79 (permalink)
Thanks Max....you reminded me to clean my "cans"..... yes they are Rob's....and no, you know this tight *** didn't pay retail....lol..... OH, they have dirty green moldy oil in them...so I flushed them out....lol
Old May 25, 2012 | 08:36 PM
  #80 (permalink)
maxcichon's Avatar
Thanks, guys. Doc, how much after how long?
